Test the water: 1988 Alpine White in CA
  • Test the water: 1988 Alpine White in CA
    I am posting this ad to test the water for possibly selling my E30. It is Alphine white with black interior and factory option 16" BBS 2-piece wheel. I purchased in 2003 with 125K miles and currently at 158,6xx miles. I am the 3rd owner. No major accidents with almost original paint, except front driver side fender repainted in 2005 (motorcycle fall on it in the garage)
    I have original books and a complete tool box in the car. California car with clean title in hand. I also have car fax available.
    Below are the major service records under my ownership. There lot more things I don't remember now but I have receipts for things i purchased and done to it.
    2003 (125k miles)
    1. Major tune up
    2. Timing chain tensioner
    3. Valve adjustment tensioner
    4. Backing plate and wheel bearing replaced
    5. H&R sport springs + Bilstein shocks
    2004 (138K miles~)
    1. Sony front deck
    2. Focal speakers
    2007 (149k miles)
    1. EVO Clutch disc
    2. EVO flywheel
    3. Crankshaft main bearing seal
    4. Exhaust manifold gasket
    5. Control arm bushings
    6. Ignition coil
    7. Distributor cap & rotor
    8. Spark plug tube seal
    9. Coolant reservoir hose
    10. Fuel injection relay
    11. Front lower right control arm & ball joint
    2010 (156k miles)
    1. Breather hose
    2. Sachs clutch master cylinder
    3. Clutch switch
    4. Spark plugs
    5. 1-piece illuminated shift knob
    2011 (157,771 miles)
    1. Major tune up (Bavarian Professional)
    ** Compression test: (1) 225 (2) 225 (3) 240 (4) 230
    2. Windshield washer check valve/T-connector
    3. Intake air flow meter boot
    4. FTE clutch master cylinder redone
    5. Left front wheel bearing
    6. Supersprint rear section muffler & new exhaust hangers
    2011 (158,255 miles)
    1. OBC light bar
    2. Soundstream reference 405 amplifier
    Parts in hand but not installed
    1. Shift rod joint
    2. Knock sensor
    3. Rear sway bar link
    4. Rear outer subframe bushing
    5. Rear control arm bushing
    6. Differential mount
    7. Front strut bumpers
    8. Clutch fork lever for release bearing
    9. Oil pan gasket, lower
    10. Oil pan gasket, pan to block
    I would like to ask for $18K or serious offer. Call 510-331-1688 or email [email protected] for questions.
    Peter
    You need to link to pictures. For some idiotic reason, this forum lets you attach in the classifieds and then erases the attachments.
    2006 GMC Sierra 2500HD 4WD LBZ/Allison
    2002 BMW M3 Alpinweiß/Black -
    AST 4100 500/500, Fikse Profil 13
    1999 323i GTS2 Alpinweiß
    1990 325is Brilliantrot/Tan
    - GC
    1989 325is Alpinweiß/Black - S50B30,GC/Koni, BBS RX, Peerless Skid, Sway
    1989 M3 Alpinweiß/Black - Basket Case
    Hers: 1996 Porsche 911 Turbo Black/Black
    Hers: 1988 325iX Coupe Diamantschwartz/Black 5spd
    272 cam, Korman driveshaft, R888s, H&R/Bilstein
      Thanks nrubenstein!
      Here is is the link to the photos. I will add more photos later this week.
      https://plus.google.com/u/0/photos/1...28467729?hl=en
        Girls If all there is true it is really big chance for anyone to score really nice e30 M3 for reasonable money. Looks beautiful on the pictures!
          Thanks oliwer78! I babied the car and hate to let go. But with recent house purchased and a upcoming wedding next year, I am considering to let go if the price is right.
            Beautiful ride GLWS.
              I looked thru the history and would like to update below.
              Purchased in 08/2003 with 139K miles and currently at 158,6xx original miles. No major accidents with almost original paint, except rear wing repainted in 2004 and front driver side fender repainted in 2005 (motorcycle fall on it in the garage)
              Never tracked and only drives on the weekends.
              2003 (140k miles)
              1. Major tune up
              2005 (142K~ miles~)
              1. Sony front deck
              2. Focal speakers
              3. Tie rod end replaced.
              2007 (149k~ miles)
              1. EVO Clutch disc
              2. EVO flywheel
              6. Ignition coil
              12. Front & rear brake rotors and pads replaced
              2010 (156k miles)
              1. Breather hose
              3. Clutch switch
              4. Spark plugs
              2011 (157K~ miles)
              ** Valve adjusted with result
              2011 (158K~ miles)
              1. OBC light bar
              1. Shift rod joint
              2. Knock sensor
              Cons: A/C not working (need new AC compressor), Inner tie rods are worn, horn not working.
              I have also uploaded more photo with picture of the interior.
                looks awesome....glws....
                josh
                  After few days of serious consideration, it is too difficult for me to let go. Thus, I have decided to hold on to it for now.
                  Thanks for everyone that interested on my E30.
