Hi Gents,
Just wondering if anyone is interested in an MK60 retrofit kit for their E30's?
I have developed a kit for our cars that allows for a simple bolt on solution for the wheels speed sensors and front brake pressure sensors.
Below is a basic overview of the system components.
The system is partially programable and fully alone, which will bring a host of technological advancements over what is currently available for our cars. The nearest unit that comes close is the Bosch Motorsport ABS system. The additional advantage is the MK60 will output a speed signal to S54 and with a steering angle sensor you will have full DSC and ASC+T (traction control, a must with 340hp!!!). The MK60 can also communicate to many after market dash systems which are compatible with the E46 M3 CAN protocol. I have mines connected to an AIM Pista and that data logs many channels.
Some more information about the MK60 DSC
The hydraulic unit consists of the following:
Four inlet solenoids
Four outlet solenoids
Two changeover solenoids
Two charge solenoids
It is designed to maintain the vehicles stability during:
ABS braking regulation
ASC+T traction control
DSC for oversteer and understeer control (can be switched off and only ABS will be in operation).
Additional features are also programmed into the control module.
These features are:
CBC - Corner Brake Control
EBV - Electronic Brake Proportioning
MSR - Engine Drag Torque Regulation
ADB - Automatic Differential Brake
DBS - Dynamic Brake System
I would like to propose to all those that are interested in a kit which will enable you to fit the Mk60 unit to any E30 with 4 or 5 stud suspension.
In the ABS kit you will receive;
2 x Front Speed Sensor adaptors.
2 x Master cylinder pressure sensor adaptors.
1 x Part Number List.
1 x Wiring Diagram + Instructions.
In the DSC kit you will receive all the of the above +
1 x DSC column kit.
1 x Programming for the E30 chassis.
The ABS Kit will retail for £199
The DSC Kit will retail for £399
For an additional cost, I can program CSL/M-track mode on to the DSC and CSL ABS program, I can also provide data cables for diagnostics and fault code reading as well as service functions (such as Steering angle sensor calibration etc),
Some photos - As you can imagine, a lot of time and work has been spent in building up this kit, the photos are taken in such a way to stop people copying the designs before any have sold!
The Steering angle sensor is still going through development, this is a solution one of my friends came up with and this is one we are going to develop further.
More photos and information to come.
Any questions, please ask away - To date, eight kits have already been sold!
Andrew
These features are:
1 x DSC column kit.
Andrew
