S14 parts and getrag 265/5
  • S14 parts and getrag 265/5
    Hello
    Due sold my M3 I am offering spares i collected.
    All parts located in Finland. Seriously buyers feel free to ask pics (e-mail) and details.
    -sportgetrag 1987 E30M3, 250tkm. Has all gears, but moans like tomcat in moonlight. Needs love and care. 1400€
    -sportgetrag 1990 E30M3, 145tkm. 500km since maintenance, one new bearing and clearances adjusted 3200€
    -sportgetrag, 3500km since rebuild: all new bearings and syncros. Billet centersection, not beautyqueen but very strong 3200€
    All gearboxes include clutch housing for S14.
    -lower + upper oilpans. Lower has better baffle, but misses rubber flap and oil level indicator. Upper one has extra breather, but can easily be removed. 550€
    -valve cover 325€
    -new propeller shaft in unopened box. 450€
    -oilfilter head 100€
    -1987 s14b23 engine block. Bore 94mm, block height 217.48mm (-0.12mm). Oil squirters. Includes timing cover (new M10 part modified to be as s14 part, s14 cover was nla) with turbo oil drain, easy to remove if no need/causes life threatening eczema. 1700€
    -46 itb*s without throttle linkage parts 250€
    -spark wires. 10500km. Practically as new, set, but distributor end hats shortened few mm's for wastespark coil, however works ok with stock distributor. 190€
    -exhaust side water gallery/pipe to head. Added extra thread for temperaturesensor in front/7left side. 50€
    Harri
    SOLD: -sportgetrag 1987 E30M3, 250tkm. Has all gears, but moans like tomcat in moonlight. Needs love and care. 1400€
      SOLD: -exhaust side water gallery/pipe to head. Added extra thread for temperaturesensor in front/7left side. 50€
        PM sent. Interested in oil filter housing and itbs.
          SOLD: -oilfilter head 100€
            Free delivery to Munchen, Germany 12.7.2018
              Updated...
              -sportgetrag 1990 E30M3, 145tkm. 500km since maintenance, one new bearing and clearances adjusted. Includes bellhousing. 3000€€ euros
              --lower + upper oilpans. Lower has better baffle, but misses rubber flap and oil level indicator. Upper one has extra breather, but can easily be removed. 500€€ euros
              -valve cover 300€€ euros
              -new propeller shaft in unopened box. 400€€ euros
              -1987 s14b23 engine block. Bore 94mm, block height 217.48mm (-0.12mm). Oil squirters. Includes timing cover (new M10 part modified to be as s14 part, s14 cover was nla) with turbo oil drain, easy to remove if no need/causes life threatening eczema. 1600€€ euros
              -46 itb*s without throttle linkage parts 250€€ euros
              -spark wires. 10500km. Practically as new, set, but distributor end hats shortened few mm's for wastespark coil, however works ok with stock distributor. 170€€ euros
                M3TT Perhaps this 2.3L block is an option for you.
                https://s14net.vbulletin.net/forum/s...-cylinder-head
                1988 Lachs - sold
                1988 DS - sold
                Bay Area M3 FB group
                  Pm sent
                    These parts still available
                    -sportgetrag 1990 E30M3, 145tkm. 500km since maintenance, one new bearing and clearances adjusted. Includes bellhousing. 3000euros
                    -new propeller shaft in unopened box. 400euros
                    -46 itb*s without throttle linkage parts 250euros
                      -sportgetrag 1990 E30M3, 145tkm. 500km since maintenance, one new bearing and clearances adjusted. Includes bellhousing. 3000 €euros
                      -new coverings (sheetmetal sill?) 41351935897 + 41351935898 200€ euros both
                        available
