FS:S14 engine
  • FS:S14 engine
    Hello.
    I am offering this engine on behalf of my friend.
    Engine has 0 km after rebuild and is located in Finland (1 hour from port of Turku).
    Engine is rebuilt with new parts. Block, head, oilpans etc are used. Bolts and nuts are zinc plated.
    Engine specs:
    -S14B23 block. Bored and deck skimmed
    -S14B25 crank + bearings
    -carrilllo rods
    -JE gr-a replica pistons 95mm, CR 11.75:1
    -S14B23 head, modified/gas flowed, with bigger S38B38 valves
    -evo3 valve springs
    -Ti retainers
    -S50B30 followers
    -292/284 schrick cams (cnc-grinded from new 308's)
    -adjustable cam gears
    -timing chain, rails and tensioner
    -new evo3 flywheel
    -new evo3 oilpump, sprocket and chain
    Other parts including:
    -46mm itb's from 167tkm car
    -48mm airbox kit (John S14) new
    -200 hp non-cat header
    -starter motor from 167tkm car
    -engine loom
    -ignition wires
    Asking price for engine and parts is 13500
    More pictures and specs available for serious buyers,
    -Harri
ID:	1270210Click image for larger version
ID:	1270209Click image for larger version
ID:	1270208Click image for larger version
    Sold
