steveseuro s14 engine parts,cleaning out my garage
  • steveseuro s14 engine parts,cleaning out my garage
    parts :
    2.5 head gasket 11 12 1 316 907 $100.00
    2.3 head gasket 11 12 1 319 445 $50.00
    evo II lower air filter housing 13 71 1 312 330 $ 200.00
    2.5 mass air flow meter 0 280 203 027 1 286 064 used $300.00
    2.3 stock m.a.f. 280 203 016 used $100.00
    cam carrier complete $ 1000.00
    throttle cable used $ 40.00
    dip stick and tube used $ 50.00
    2 oil filter housing used $ 250.00
    1 exhaust header stock used $ 300.00
    1 valve cover used $ 300.00
    1 distributor housing $ 150.00
    1 main bearings std. glyco $ 75.00
    1 rod bearings std. glyco $ 40.00
    lower oil pan used $ 250.00
    upper oilpan used $ 250.00
    fuel rail with injectors used $ 250.00
    motor mount bracket 31 11 2 225 583 used $ 100.00
    motor mount bracket 2 225 584 used $100.00
    cam gears stock used $ 100.00 ea.
    exhaust cam gear A100 used $100.00
    set camshafts stock used $100.00 ea.
    all prices are USD.
    parts are located in toronto canada
    pictures on request.
    PM sent
      TtT for a good seller.
        Sent you a PM.
