Massive e30 m3 parts clearout
  • Massive e30 m3 parts clearout
    Hi All,
    having sold my e30 m3 and a friends project car I have a huge pile of various e30 m3 parts left over.
    All prices are indicative so if you feel something is overpriced feel free to make a sensible offer.
    All parts are located in the UK midlands but can be shipped anywhere at the buyers expense.
    Given the volume of parts there are no pictures at present but i will look to add these where time allows.
    E30 M3 front bumper towing eye covers left and right (priced each) 100.00
    Pair OEM M3 Evo 2 camshafts inlet & exhaust 850.00
    Single Schrick camshaft for inlet or exhaust 284 300.00
    New Ferodo DS2500 front pads for standard caliper E30 M3 80.00
    Tired but functional body wiring loom and very good engine harness POA
    Cyntex Jim Conforti Alpha N chip & wiring loom 350.00
    Maxx Automotive Alpha N Kit with loom (used), data cable, V2 built 05.08 serial 000421 500.00
    Kit to allow OEM front top mount to run additional negative camber 25.00
    Grey E30 M3 OEM kickstrip - Cecotto (m3 logo) x 1 not handed 100.00
    E30 M3 rear axle camber adjustment plates (weld on) - 2 x full sets 100.00 or 50 each
    E30 m3 centre console with cassette holder and heated seat switches. Console is tired 40.00
    RHD centre console around gear shift - mint, no holes anywhere for switches 75.00
    GRP Sport Evo spoiler with GRP gurney flap unpainted never fitted 300.00
    Drivers side E30 M3 OEM front wing. Bit rotten at the bottom so will need repair but otherwise very sound with no dents 100.00
    Main exhaust heatshield - mint 50.00
    LHD e30 m3 dashboard some damage 300.00
    E30 M3 OEM airbox, with AFM & K&N filter 150.00
    heavy aluminium centre heatshield 25.00
    fuel filler neck rubber gasket 10.00
    obc control module 25.00
    OEM amp & antenna booster for upgraded hifi 40.00
    OEM e30 m3 electric fan 50.00
    washer fluid reservoir 10.00
    coolant tank reservoir, sensor and pipes 25.00
    OEM airbox snorkel 50.00
    Ignition lead cover 10.00
    rare cruise control module and motor/cable/stalk OEM 250.00
    wheel speed sensors front and rear 200 for 4
    e30 m3 indicator stalk with obc function 45.00
    front grills inner and outers with M3 badge 150.00
    boot lid inner plastic trim (the top where the latch is) 10.00
    passenger side carpet kick strip 5.00
    Brand new full alloy radiator 100.00
    mint intake boot AFM to inlet manifold 10.00
    dash cluster plug to allow retrofit for cruise control etc (green socket) 25.00
    check control panel 50.00
    fuel tank cover x 2 10.00
    Sport evo front bumper seal - single piece 35.00
    complete distrbutor housing & distributor cap 150.00
    rotor arm topran new 20.00
    braided brake line set new 55.00
    braided clutch line New (Hel) 25.00
    Throttle blocks mint 70.00
    new oil pressure switch 5.00
    central locking module mint 75.00
    gong 10.00
    OEM new front bump stops 10.00
    Sport evo OEM front wing seals 45.00
    Fuel pump bracket OEM new 35.00
    Superpro PU alternator bushings 20.00
    door seals for both front doors 50.00
    Bosch Motronic OEM E30 M3 ECU 500.00
    Bosch ABS E30 M3 35.00
    Mint rear ashtray 10.00
    Inside glovebox plastic 10.00
    Pair mint A pillar covers 150.00
    Mint nappa leather gear surround 25.00
    Under cluster plastic cover perfect 10.00
    Perfect OBC & heater panel 140.00
    instrument cluster surround 10.00
    headlight switch & surround 25.00
    OBC bleeded screen 35.00
    mint dogleg gearknob 30.00
    Kenwood dualmag front door speakers - Mclaren F1 50.00
    I'm interested in the electric fan. Will PM you.
      Hi all, some of the items listed seem to be missing from the pile! Apologies for any confusion, i have updated the list as per the below:
      Standard e30 m3 flywheel, good condition no scoring or damage 100
      Set of 4 standard pistons in very good condition all from the same engine 300
      gong 10.00
