S14 Complete Engine
  • S14 Complete Engine
    S14 complete engine for sale
    $6500 U.S.D
    I Will Facilitate Packaging & Shipping
    True Mileage Unknown (purchased as spare engine)
    I have lots of extra parts and lots of hardware
    Complete Unmolested & Engine Harness
    Crank Pulley & Harmonic Balancer
    AC Valve & Hoses
    Lifters & Engine Hardware
    Heat Shields
    Camshafts
    Coolant Tube
    Cam Housing Rear Cover
    Timing Chain Pulley
    Alternator
    Coolant Hoses & Tee
    Oil Pan
    Evap Hoses
    Distributor housing & rotor Pulley
    Lower Oil Pan
    Valve Cover
    Camshaft Housing
    Front Cover
    Upper Oil Pan
    Coolant Tube Housing & Sensors
    Engine Mount Brackets
    Starter
    Throttle Body
    Injector Housing
    Power Steering Pump & Pulley & Bracket
    Hardware & Small Bolts in Plastic Bags
    VAC Stage One Head (Never Used)
    Short Block With Oil Pump
    One Piston Badly Damaged But Cylinder Bore Is OK
