Massive Group buy - 332x32mm BBK for AP Racing or Wilwood calipers
  • Massive Group buy - 332x32mm BBK for AP Racing or Wilwood calipers
    The last production of hats was 3 years ago and I am currently out of them. The inventory is totally dry.
    These kits can be fitted w/ AP Racing CP8350 calipers as offered by Essex as well as with Wilwood 6-piston radial calipers
    BBK fits 17x8 ARC-8 rims with ample clearance and without spacers.
    https://www.facebook.com/pg/Massive-...54170948025037
    https://www.facebook.com/pg/Massive-...67438133364983
    The Wilwood-based kit can be fitted with a larger 355x32mm rotor. Same hats but different radial mount.
    Considering the e30 M3 is now a very tiny niche market, I will NOT stock on those kits.
    But I will produce them if I have 10 orders.
    Either as complete installation kits or rotors and drive-pins only. As usual, client can source the rotors and calipers separately from his usual supplier.
    Price of a complete installation kit is the same for Wilwood or AP Racing-based kits at 1200$cad / roughly $900usd
    Price of hats/drive-pins/setscrews is 900$cad / roughly $675usd
    Free shipping on this GB.
    If you are interested, then simply add your name. When we reach the magic number of 10 orders, then I'll go into details.
    Lee
    [img] https://scontent.fymy1-1.fna.fbcdn.n...66&oe=5E54CF6D [/img]
    [img] https://scontent.fymy1-2.fna.fbcdn.n...94&oe=5E615FE1 [/img]
    [img] https://scontent.fymy1-1.fna.fbcdn.n...db&oe=5E504523 [/img]
    [img] https://scontent.fymy1-1.fna.fbcdn.n...18&oe=5E1D0B8F [/img]
    Ron C is in!
    Ron ///Man
    • '89 M3 M3T / ITR Club Racer
    • '94 Spec E36 - Eh....
    • '09 M3 - Tarmac Terrorist
    • '07 530 Xi - Highway Star
      Originally posted by Ron ///Man View Post
      Ron C is in!
      Taking good note, Ronnie Boy.
        In regard of brake pad costs. Price is much lower for a Wilwood Superlite caliper (and as the AP caliper uses the same pad shape, benefit is the same) than for a BMW calipers.
        You get to save $90usd at each pad change if using Hawk HT10 brake pads.
        Hawk's HT10 brake pad for a Superlite caliper costs $126usd
        https://www.summitracing.com/parts/h...-800/overview/
        And the dame compound for a BMW caliper costs $216usd
        https://www.bimmerworld.com/Brakes/B...ds-HB135S.html
        The money saved at pad changes helps you pay for the BBK ;-)
          Is it possible to get just a set of the rotor hats? Looking for some spares for a rainy day...
          1987 325is - 185-195k
          1988 M3 - 141k
            Yes. It is possible and part of the current offer. You get 2 black anodized aluminum hats and 24 stainless steel drive-pins and teflon seals. BMW setscrews and all fasteners.
            Cost is 900$cad and free shipping with this Group Buy.
              I have Lee's kit and I can't recommend it enough. I bought it for a number of reasons but the lower cost of annual consumables makes it work for me. I do 6-10 track weekends / year and one set of pads and rotors usually does the trick for me.
                Hoping we can find 8 more "in's"
                  Start by putting down your name ;-)
                    [QUOTE=
                    [/QUOTE]
                    Now if we can just get them made
                      I have one more in as well for just the hats/pins... Phil?
                        Is there a rear kit available?
                          Yes. There are rear kits available. Several options to chose from and in stock at the moment.
                          - 300x32mm or 310x32mm two-piece fixed rotors with lug mounted 4-pistons Wilwood Superlite calipers or Wilwood Dynalite
                          - 300x32mm two-piece fixed rotors with radially mounted 4-pistons AP Racing CP8350 calipers. Same kit as in the link below but with correct e30 M3 hats.
                          https://www.facebook.com/pg/Massive-...81777238597742
                          Both above kits can retain the OEM handbrake mechanism by using optional bolt-on steel handbrake drums.
                          - 332x32mm two-piece floating rotors with radially mounted 4-pistons Superlite calipers. Great for high performance endurance racecars. No handbrake option.
                          https://www.facebook.com/pg/Massive-...69104276531701
                            That same kit using WIlwood's radial Superlite caliper can be optioned for a larger 355x32mm (14"x1.25") rotor. The specific radial mounts are already in stock.
                            https://www.facebook.com/pg/Massive-...67446376697492
                              Lee, when would you plan on manufacturing?
                              Dan
                              88 M3
                              Black on Black
                              San Diego, CA
                              USA
