I have some S14 engine and other M3 parts for sale. See below, I will add pics later but nothing listed is damaged, everything is in good shape. Prices are OBO + shipping.
1. Single S14 con rod, extra/spare leftover from some engine teardown (was not over rev'd or part of a failed engine), $100
2. Cam box cam gear cover plate, $50
3. Cam box distributor carrier and rotor mount, $150
4. Pair of factory cam gears, $100/pair
5. Pair of factory cam gears, stock intake & evo exhaust (A100), $160/pair
6. Set of 4 stock cleaned injectors but they're without the paperwork. I think they were installed at one point but I know they were never run. Work was done by Cruizin Performance, $175/set
7. E36 M3 timing chain tensioner, used - I think for one weekend, then engine was torn down, $75
8. Pair of oil pan baffles...one is stock, no damage, the other is aftermarket with the additional vertical edge (formed, not welded on) - on this one the L mounting bracket rivets are broke, need to be reattached better, parts are included, both have the rubber flap, $75/pair
9, Front subframe, motor mount area has typical fatigue damage on one side but also includes a set of new in package Turner reinforcement pieces, $175
10. Factory brake duct inlet, new in package, RHS, $40
11. Factory throttle pedal, new, build date up to 9/87, $25
12. Factory throttle pedal, new, build date 9/87+, $25
13. Single ABS ring, used, no damage, $60
14. 2x Used ABS pumps, $60/ea
15. 5x rear main seal carriers, $30/ea
16. Turner reinforced rear sway bar brackets, used, $60/pair
17. Bosch coolant temp sensor (blue) and FAE temp gauge sensor (brown), both new with crush rings, $25/pair
I can provide pics if desired.
