FS: Miscellaneous Parts
  • FS: Miscellaneous Parts
    I've got the following parts for sale as a result of converting my race car back to a street car and also building out a 2.5L motor. All prices exclude shipping and any payment fees.
    Photos here: https://photos.app.goo.gl/2YSRRLrzbDLaY7EF7
    • Complete matched set of used S14 OEM rods and pistons - approximately 30K miles - prefer to sell as a set: $600 rods, $300 pistons
    • S14 46mm throttle bodies and isolator blocks - completely unmolested: $1000
    • S14 2.3L used header, but perfectly good: $150
    • OEM S14 headbolts (used) and washers (new) - $75
    • S14 Sachs Clutch/Pressure Plate/TO Bearing - 10K miles on all: $175
    • S14 AC compressor - working state unknown: $200
    • S14 AC bracket - complete with all new bushings and bolts: $250
    • E30 Cruise Control ECU (I have two): $100/each
    • Sparco seat slider w/ very low seat bracket - for all E30s - bolts into factory location of stock seats - nice setup: $200
    • OEM E30 M3 fan with a good, relatively new fan clutch: $150
    • Complete set of used S14 OEM 2.3L valves, springs, retainers - very good condition: $250
    • Used Ground Control Delrin front control arm bushings - perfect (https://groundcontrolstore.com/produ...with-bearing): $150
    • Complete set of Dinan J-Stock springs/shocks - shocks revalved by ProParts (approx. 3K miles on them) - awesome setup: name your price
    • Solid aluminum rear subframe bushings for all E30s - made by Dinan (when Dinan was run by Steve): $125
    • S14 used alternator - very good condition: $125
    • S14 used starter, but good working condition: $100
    • S14 motor mount arms: $125
    • S14 Air plenum bracket - bolts to block and plenum: $50
    • S14 used oil separator: name your price
    • Qty 1 - S14 stock 2.3L cam - slight pitting on one lobe: $200
    • S14 used exterior fuel pump - good working condition: name your price
    • OEM Behr radiator - 10K miles - replaced in the process of tracking down an overheating problem... new radiator made no difference: $125 (new is now ~$450)
    • E30 M3 Engine Fan w/ fairly new fan clutch: $150
    • S14 known good ABS pump: $1000 firm
    • SPA AFFF Electric Fire Supression System 4 liter; complete system (more or less this: https://competitionmotorsport.com/lifeline-zero-360-fia-3-0kg-novec-1230-electric-system). Fully charged, but will need recertification: $400
    Also have a set of four Kosei Racing wheels... 15x8 with E30 M3 lug pattern. Used, but in good condition and straight. No tires mounted and prefer local pickup. $300 for the set.
      What is the location of the parts (K1s)?
        Los Angeles. Yes, I should have mentioned that they're K1s, but anyone who knows what Koseis are knows that.
          Damn, OK, if you were in the northeast I would have taken them.
          GLWS of all your parts.
          Cheers
          jimmy p
            Thanks Jimmy.
              Updated list of parts for sale:
              • S14 Sachs Clutch/TO Bearing - 10K miles on all - no wear visible: $50
              • E30 Cruise Control ECU (one remaining): $100
              • S14 Air plenum bracket - bolts to block and plenum: $30
