Stock shifter assemblage / valve cover
  • Stock shifter assemblage / valve cover
    Looking for a complete-ish shifter assembly, want to try something before I spend the big bucks on a fancy shifter. I think the e30 325 assembly is the same.
    Also looking for a valve cover- so I can make one pretty and still drive my car...
    970 to two too 9597
    Thanks.
    Dave.
    Dave.
    76 M2
    Dave which part you need? Highlight the screen on real oem and let me see if I can help.
    Finnally Powered by my ///M3
    1990 E30 M3
    1973 M2
      Thanks Hamik. I suppose at a dead nuts minimum, 1 and 12. It would be nice to have bushing 4. The rest of the pieces would be nice. 2 isn't necessary, nor is 7, but if someone had all of it I'd take it. Basically the mechanical bits.
      I'm contemplating getting rid of the ball on 9 and the socket 10, and using a spherical bearing pressed into 1, with relevant changes to 9 to work with it. What would be nice about that is it would be very easy to change the motion ratio of the shifter on the spot without needing a complete new 9. Just something I've been thinking about for a while. It would probably require fabrication of 9 as it would need to go in the lathe, but basically it's a bent rod with a loop on the end, and I think someone mentioned using needle bearings in there? At the pivot to 12?
      Dave.
      76 M2
        I have them all.
        1990 E30 M3
        1973 M2
          Dave,
          Browse at 123Bearing.com for the size you need. If it exists they have will them with and without grease seals.
            I have them all.
            Sweet. Can you part with them for $150 shipped?
            Dave.
            76 M2
              Originally posted by JimK View Post
              Dave,
              Thanks Jim.
              Dave.
              76 M2
                Dave,
                See post #3 in this thread. Mick had some good suggestions. I went with his suggestions and was impressed with the results. This might be the solution you are looking for.
                Shifter Buzz - How To Eliminate - S14.net (vbulletin.net)
                Mark
                1990 M3
                  Originally posted by mwagner10702 View Post
                  Dave,
                  Mark
                  Thanks Mark. Went a step further and just ordered the kit Marshal had listed at the end from Turner. I'm sure that'll all help. Thanks.
                  Dave.
                  76 M2
                    Glad I could help. A couple of notes:
                    1) Per Mick - "If you buy the kit remember to not use their delrin front carrier bushings (for 4)". I have a set of Powerflex Black Series bushes for #4 if you want them. No charge, PM me your address and I'll send them out.
                    2) I'd recommend going with the UUC DSSR if your budget allows rather than the OEM selector rod.
                    Mark
                    1990 M3
                      Mark
                      Thanks Mark.
                      Dave.
                      76 M2
