FS: (Finally) Special Snorkel with integrated Airfilter for the BMW M3 E30 DTM Airbox
    Mine just showed up, however I can't open it as my wife saw it and insisted on wrapping it as a gift to me for New Years. One more day, Thanks Markus!
    Dan
    88 M3
    Black on Black
    San Diego, CA
    USA
      Got mine yesterday - really nice quality. Thanks again Markus!
        Originally posted by Markus View Post
        ok guys, these 9 Units are sold now.
        Hope to get the last 6 pieces in the end of january.
        So let's make a list for the last ones
        1: Mick
        2:Ladrillo
        3:
        4:
        5:
        6:
          Markus please put me down for one.
            1: Mick
            2:Ladrillo
            3:BM3MW
            4:
            5:
            6:
              Put me down for one please
                1: Mick
                2:Ladrillo
                3:BM3MW
                4:S4Del
                5:
                6:
                • #23
                  1: Mick
                  2:Ladrillo
                  3:BM3MW
                  4:S4Del
                  5: t2540
                  6:
                  • #24
                    1: Mick
                    2:Ladrillo
                    3:BM3MW
                    4:S4Del
                    5: t2540
                    6:
                    Hi Markus, put me down for one
                    • #25
                      1: Mick
                      2:Ladrillo
                      3:BM3MW
                      4:S4Del
                      5: t2540
                      6: Alvy26
                      if i'll get more then these 6 then i'll post it here
                      • Rcgalore
                        Rcgalore commented
                        Editing a comment
                        markus… I will be on list if available…..need one…
                    • #26
                      Is everyone just drilling an extra hole in theirs and using the factory bolt that holds the plastic shroud? I noticed the snorkel is quite close to the ps pulley so wanted to be sure that would hold it up high enough not to interfere.
                      Also - are you eliminating the factory snorkel tube and plastic shroud? It seems to fit over it ok. Removing that creates a gap between the rad and filter housing...
                      Thanks.
                      • #27
                        I wanted to send a big thanks to Markus, Got mine recently and it looks awesome. If anyone has any advice on installing it let me know. Thank you.
                        • #28
                          There are some pics of my install here, not much but it may help.
                          https://s14net.vbulletin.net/forum/s...48#post1300048
                          Because the flange on the filter doesn't quite fit the opening, I made an adapter plate out of a sheet of CF and attached the filter to that.
                          Fabbing odd shaped pieces is always tricky and requires lots of trimming and test fitting. To do the job right you really need to remove the bumper, under tray, grilles, fan/shroud, and loosen the radiator to move it out of the way. When I did mine I had the hood removed as well, which made it much easier to position the pieces when working alone.
                          You may find that the lower fan shroud attachment point is in the way and doesn't allow you to position the filter in the ideal spot. I trimmed mine off with a small hack saw and created a new attached point lower down using a small nut and bolt. It'll make sense when you see the issue.
                          I also found that the section of hose it came with was too short and I need to buy another that was about 40mm longer
