All Parts are used and in good condition unless stated otherwise:
Engine:
2.3L Motor 130K mi – Complete $2,600.00
2.3L block $600.00
2.5L block $850.00
2.5 US Block w/EVO III Pistons $1,250.00
Schrick TI Retainers - New $600.00
Valve Springs - used ///M $225.00 set only
Cam Gear: A100 E II $75.00
Cam Gear: Stock - $50.00
Cam Stock $175.00
Cam - Custom New (2) $800.00
Cam - Custom $400.00
Crank - Stock - Spun Bearing $100.00
Crank - 2.5 E III $450.00
Rods - Carrillo Set of 4 $850.00 set only
Rods - LTW Factory Set of 7 $850.00 set only
Piston - 93mm $50.00
Pistons - 95mm (New) $550.00 set only
Pistons - 95mm $400.00 set only
Throttle Bodies: 46mm $300.00 set
Air Horn /Venturi 46mm $175.00
Throttle Bodies: 48mm w/Horn - US Bored $1,400.00
AFM $150.00 Intake Plenum $200.00
Exhaust US 84K $450.00
Header Stock $100.00
Engine Mount Arms $50.00 Per Pair
Valve Cover - Needs Refinish $185.00
Oil Pan - Upper $150.00
Timing Cover $100.00
Spark Plug Loom $75.00
Ref / TDC Loom $100.00
Motor Mounts - 7 Series $50.00 set only
Driveline:
Gearbox - Blanton Reb. $1,200.00
Gearbox - Used $650.00
Diff 4.10 Stock 84K miles $600.00
Diff 4.10 75% $1,250.00
Diff 4.27 Blanton 75% $1,650.00
Bell Housing $250.00
Pressure Plate Stock - New $175.00
Pressure Plate Sport $275.00
Pressure Plate Sport - Slight Scoring $175.00
Flywheel - Alum $225.00
Diff Cover Stock $50.00
Electrical:
Engine Harness $250.00
Chassis Harness $350.00
ECU 071 - Used $350.00
Gauge Cluster - 165K mi $100.00
Gauge Cluster - Euro $150.00
Suspension & Steering:
Top Mounts Gr-N $300.00
Steering Rack 31K miles $300.00
Steering Wheel $125
K-Mac Rear Camber Kit - New $175.00
GC camber/Caster Plates $225.00
Misc:
///M Dead Pedal $300.00
Snow Tires (2) $75.00
UUC Pedal Covers - New $85.00
VSR Shift knob $25.00
Factory ///M Shift knob $50.00
Factory /// M3 Shift knob & boot $50.00
Factory tool kit - Complete $100.00
Factory tool kit - Incomplete $75.00
Wheels Chrome Wheels W/4 Caps (5) $600.00 set only
Brakes:
Wilwood Calipers - 4 Pot - New (4) $400.00
Wilwood Calipers - 4 Pot (4) $200.00
Race Parts:
Race Seat - Cobra w/brackets $400.00
Race Seat - Ricer $250.00
Race Seat Brackets - Cobra $100.00
Race Seat Brackets - Sparco $100.00
E30 M3 Garage Sale
E30 M3 Garage Sale
Ron ///Man
- '91 Gr-A Former CiBiEmme / Ravaglia - Sold
- '90 M3 Faux EVOII Alpineweiss 36K Orig Owner - The Queen
- '91 M3 Faux EVO III Brilliantrot Euro Driveline - The Rocket
- '91 M3 Faux Gr-A Club Racer DM - The Alter EGO
- '89 M3 M3T / ITR Club Racer
- '94 Spec E36 - Eh....
- '09 M3 - Tarmac Terrorist
- '04 330Xi Sport 6 Speed - Snowmobile
- '07 530 Xi - Highway Star
- http://www.imwcarparts.com/e30-m3-parts.htm
Tags: None
Sorry, the Wilwoods will NOT fir over 15 inch wheels. Some 16's are questionable too. Most 17's will clear them. These are race parts that will take some fab work to fit up!
Ron ///ManRon ///Man
Cluster
Interested in purchasing the "Gauge Cluster - 165K mi $100.00"
Can you please send me a picture to [email protected], and type of payment.
DAnDan
12/87 Zinnoberrot
3/87 Henna
Is the sparco mount bottom or side mount?
Also, can you send pictures of the shift knobs to [email protected]?
Hi Ron.
Are the calipers the Forged Superlite with 1.75" pistons? are they for 1" or 1.25" rotors?
TIA
Can you post a picture of the shifter or email one to me. also can i make a payment to you though paypal.
[email protected]:
