OK, here is my list. Sorry for the delay, but I had to entertain some folks before I could post it.
This isn’t an auction per se, but it is first pay-first serve. If you want something, you have to send me an email at [email protected] and indicate what parts you want. I won’t be tracking my listing or my private messages, only my email, so please don’t send me a message on S14.net. I will answer emails one at a time starting with the first one I receive and offer the item to that person, if I receive payment from the first to show interest then the rest are out of luck. If the first waffles, then I’ll move on to the next in line and so on and so forth.
All prices exclude shipping, handling, insurance, crates, pallets, etc. I prefer to ship either UPS or UPSP priority. I will insure any item for any amount, but only if you request it and pay the additional amount. If the items aren’t insured and it’s lost or damaged, it’s on you. I prefer payments to be made through PayPal ([email protected]) but I will also accept checks and money orders. Checks have to clear before the items are shipped, so allow 10 days for that process. I will attempt to get the item shipped immediately after the payments for both the item and shipping have been received. Since I won’t have the shipping amount until after the item is sold, packaged and weighed, I will need two payments. The first payment is for the item which allows you to make claim to it (since I am committing to sell to the first received item payment, not the first guy to say he is interested). The second payment will cover the shipping and that is to be received as soon as possible following the shipping quote I’ll send to you.
Now, I’m just one guy, I don’t have an order processing department or a shipping/ receiving department, so allow me some time to process the orders. I will try to get through them as quickly as possible.
Keep in mind that you are purchasing used car parts. I will not warranty them. You buy at your own risk. I am not out to rip anyone off or take advantage of anyone, but sometimes my perception of something may be different than yours. Try to be reasonable. I will describe the items to the best of my ability. I can provide you as many photos as you need to feel confident, but that all takes time and if the next guy in line doesn’t need pictures to close the deal, then you’re out of luck. I’m not trying to be a jackass, but I’ve been played this game before and I know what to expect.
Another thought… the prices listed are my asking prices. If you feel they are out of line, I will consider offers, but I don’t need you to bust my balls on how you can get such and such from so and so for half the money. If that’s the case, great, buy it there or make me an offer. Who knows, I might just take you up on it, but I will only consider offers after I get though everyone who is interested in the item, so I may not accept your offer immediately.
I hope you can tell from my little diatribe, I’m a straight shooter. I’ve sold stuff here and on eBay before and I have a lot of positive feedback because I don’t play games, so please extend me the same courtesy.
CF air plenum w/ snorkel, red or blue silicone tube, air filter frame/ throttle bracket (photo in gallery) $1199
Arrow H-beam rods $899
alternator w/o pulley $100
underdrive alt pulley $40
underdrive water pump pulley $125
slotted cam sprockets(photo in gallery) $350
Schrick 284 cam(photo in gallery) $450
Schrick 276 cam(photo in gallery) $450
Evo 3 2.5l block $1599
Evo 3 oil squirters $999
Evo 3 oil pump $175
evo 2 head w/ +2mm intake +1mm exhaust/ VAC custom springs/ bag of misc valves(photo in gallery) (at least on bent valve in #2, need #2 CC cleaned up, I’ll provide the source for replacement valves- more info available)$2199
cam tray w/ bearing caps and shim buckets $499
custom cam carrier front covers $150
water pipe (steel, from overflow to waterpump) $29
water return manifold (aluminum- attaches to head) $99
Cam cover $125
rear cam box cover plate $49
upper chain guide $30
Evo 3 Bosch green top fuel injectors(photo in gallery) $399
Adj. fuel pressure regulator w/plumbing, brackets, modified rail(photo in gallery) $149
Evo 2 piece 50/50 headers(photo in gallery) (dent in #2 tube) $699
misc water hoses and thermostat $50
6 new Bosch spark plugs XR4CS $20
Starter $100
upgraded chain tensioner $75
48mm throttle bodies (bored out 46mm w/ narrowed shafts) $849
Group N rear main seal $50
Almost new timing chain $50
almost new oil pump chain $10
ARP main studs $90
evo flywheel $499
740 motor mounts $100
535 trans mounts $50
87mm crank $599
lower chain guide (lg) $100
lower chain guide (sm) $75
chain guide rail (plastic) $10
idler sprocket ( 2 available) $20
motor mounts arm left $50
motor mount arm right $30
lower oil pan with baffle $175
upper oil pan $125
Engine bowl reinforcement $75
oil filter housing $200
Bell housing (welded repair patch) $150
timing case $100
crank hub-dampener $275
used (heat cycled) head bolts $25
water pump $99
VAC custom spring seats (new) $75
guibo (have 2) $25ea
stock plenum w/o horns $75
clutch release lever $5
stock valve springs/retainers/keepers $100
throwout bearing $20
5spd OD trans $699
5spd CR trans $1649
5spd OD trans (needs rebuild) $200
16x8 BBS RK w/245-45 Kuhmo Victoracer $499
E36 M3 brake conversion w/ 3 sets of pads/ rotors/ hats/ calipers $899
1 qt Accusump w/ oil filter adapter/ electric valve $299
HD clutch w/ 6 puck solid hub $300
Evo 3 oil pump $175
Cam cover $125
Starter $100
ARP main studs $90
evo flywheel $499
87mm crank $599
upper oil pan $125
timing case $100
water pump $99
5spd OD trans $699
5spd CR trans $1649
