<FS> Various M3 parts...LOTS!!
  • <FS> Various M3 parts...LOTS!!
    Ok gang, here's the mother load! Check it out....
    Please note that some items listed below are the same as the items from a previous note....not just more of the same parts!
    I've got a TON of various E30 M3 spares and parts that I'm getting rid of. All parts are in excellent working condition unless otherwise noted. Making room for a new project......help me out! ; )
    All prices are OBO and do not include shipping! Email with any questions, thanks!
    2.3l GrpA head gasket, new....$175.00
    2.3l GrpA head gasket, used for less than 10 miles, as new...$125.00
    Spare trans, great shape but dirty, approx 100k on it...$350.00
    Spare trans, pretty good shape, repaired shifter attachment point, approx 82k....$275.00
    Spare trans, ok shape, 3rd gear sycros grind a bit but still serviceable, good core, approx 86k....$200.00
    Spare trans, ok shape, reverse grinds a bit but otherwise is fine, approx 96k....$225.00
    Spare driveshaft, fine shape, probably needs a center bearing, otherwise great, $100.00
    Spare driveshaft, same as above....$100.00
    Spare front subframe, old style, properly reinforced from top and bottom but will not raise engine height, was not repaired...$125.00
    DME #1, stock chip, fine shape, no problems...$375.00
    DME #2, no chip, fine shape no problems....$350.00
    Schrick cams (284/276), barely used (less than 10 miles literally)...$800.00
    Schrick cams (292/284), brand new, never installed or used....$850.00
    Schrick titanium retainers and valve keys, brand new, never installed or used....$350.00
    Adjustable cam gears, TMS, brand new, never installed or used....$325.00
    BMW Motorsport EVO exhaust cam gear, great condition....$90.00
    48mm TB's w/airhorns, factory parts, like new, used less than 2k miles, perfect, airhorns are polished...$1,600.00
    EVO3 injectors, same as above (although the injectors are not polished!)...$175.00
    EVO3 AFM, brand new, never used or installed, Bosch part....$275.00
    EVO3 AFM, used but in excellent condition, cleaned up nicely...$200.00
    Stock injectors #1, fine shape pulled from well running engine....$100.00
    Stock injectors #2, fine shape pulled from well running engine....$100.00
    Fuel rail #1, stock fine shape, nothing special, $25.00
    Fuel rail #2, stock fine shape, nothing special, $25.00
    Fuel rail #3, stock fine shape, nothing special, $25.00
    BMP aluminum front strut brace, fine shape...$100.00
    Spare cam box, bare but with journal caps and hardware....$175.00
    CF plenum - stock replica, bought new, never installed, great shape, some cosmetic blemishes, weighs 8.5lbs less than stock plenum!...$475.00
    (4) 17x8 Fikse FM5 w/brand new, never run 245/40/17 Hoosiers, great shape...$2000.00
    (4) 17x8 Fikse FM5 w/used 245/40/17 Hoosiers, fine shape, tires have good tread left....$1,500.00
    (6) 17x8 BBS RC wheels w/used 245/40/17 Hoosiers (4 tires, 6 wheels)....$1,750.00
    Set of (4) Hoosier wets in 225/45/17, ran for less than 20mins in very wet track...$725.00
    Ackerman spacers, 6mm....$125.00
    Ackerman spacers, 12mm....$175.00
    Ackerman spacers, 18mm....$175.00
    20mm spacers, new....$90.00/pair
    18mm spacers, used....$80.00/pair
    Stock header #1....$75.00
    Stock header #2....$75.00
    Stock flywheel....$50.00
    Lightened flywheel....$100.00
    I'll probably have more stuff later, especially some engine parts. That's it for now. Thanks.
    Jack
    any brake ducts?
    Seats Taken...No one rides for free...:burnbaby:
      Nope, ducts stay with the car.
      Jack
        check ur PM's.
          i think im going to take the subframe and what weight is the ltw flywheel?
          how much for shipping on the front subframe? located in NY
          thanks
          chris
          Old School
            Flywheel weighs 16lbs, about 3.5lbs less than stock. It's a stock flwyheel that was machined, resurfaced, and used for about 20miles. It's in great shape.
            I need your zip code to get a shipping cost.
            Jack
              what spacers would I need to fit E36 wheels on my car???
                15mm for mose e36 m3 rims...
                Which rims are you looking to put on? and what size and offset are they?
                ADA///M
                  its 10573
                  im not interested in the flywheel just the subframe now
                  Old School
                    The M contours 17"
                      any price on that shipping yet?
                      Old School
                        Shipping for the front subframe looks to be about $13 insured. Lemme know!
                        Jack
                          what happened with the cams?
                            ok you said the subframe was reinforced right? which kit was this or was it custom?
                            its says it was not repaired. what do you mean by that? any pics
                            thanks
                            chris
                            Old School
                              Well, if you mean are they still available, no, they're sold. If you mean otherwise then, well, I don't know what you mean!
                              Jack
