<FS> motor parts and more
  • <FS> motor parts and more
    I'm resurrecting one of my old lists. This list and these prices supersede any prior posts. All pricing negotiable and I offer quantity discounts. Shipping is not included unless otherwise stated.
    All parts are in good, used condition unless otherwise described.
    E36 M3 front brake conversion w/ 2 new and 1 used set of Hawk blues/ rotors/ hats/ calipers. Calipers include brass bushing upgrade. $829
    OEM rear brake calipers upgraded with Korman SS pistons and brass bushings. Will include stock rotors and used Hawk Blue pads. $199
    5spd OD trans $499
    5spd OD trans (needs rebuild) $199
    Euro 215 head w/ +2mm intake +1mm exhaust Supertech valves/ VAC custom 12k RPM springs/ bag of misc valves(photo in gallery) (I suspect at least one bent exhaust valve in #2 combustion chamber $2100 as is or...
    >option 1: I'll completely refurbish the head for you for whatever the parts and labor are plus the head price listed above, this will save you the hassle and you'll get a head ready to bolt on the car
    >option 2: I'll separate the valve springs if interested - $400 discount from above price
    >option 3: I'll install OEM springs - $300 discount from above price
    upper chain guide $25
    Starter $99
    Almost new timing chain $50
    almost new oil pump chain $10
    740 motor mounts + 535 trans mounts $99
    lower chain guide (lg about 100k miles) $69
    lower chain guide (sm about 100k miles) $39
    chain guide rail (plastic about 100k miles) $10
    timing chain idler sprocket (2 available) $20 ea
    Bell housing (welded repair patch) $149
    timing case $99
    crank hub-dampener $175
    guibo (have 2) $25ea
    clutch release lever $5
    stock valve springs/retainers/keepers $99
    throwout bearing $20
    16x8 BBS RK w/245-45 Kuhmo Victoracer (painted black - track wheels) $499
    VAC custom valve spring seats (new) $50
    new main bearings (M10) $50
    new rod bearings (M10) $50
    coil $20
    dipstick/tube $10
    handbrake lever $10
    oil separator $10
    stock intake rubber elbow $10
    fan w/o clutch $15
    crank sprocket $50
    power window regulator and motors (both sides available) $199 ea
    trunk carpet and side/ back/ front trim panels $100
    trunk springs - make offer
    trunk hinges - make offer
    all seatbelts - make offer
    airbag wheel in perfect condition - make offer
    knee bolster from airbag car - make offer
    trans crossmember $39
    rear fiberglass bumper insert $99
    Jeff
    NASA GTS5 #945
    NASA GTS5 Midwest Regional Champion ('09,'11,'12 & '14)
    Ground Control spherical front control arm bushings in lollypop bracket $150
    New wheel studs - 60mm overall qty 20 -$25
    TPS $10
    brake booster - $50
    stock fuel rail - $25
    5spd OD trans $499
    coil $20
    dipstick/tube $10
    handbrake lever $10
    fan w/o clutch $15
    crank sprocket $50
    distributor housing/ ex cam cover plate - $50
    Starter - sold
    oil separator - sold
    timing case - sold
    Jeff
    NASA GTS5 #945
      Jeff,
      What wheel arrangement were the studs for? I would take them if they are suitable for 18mm spacer and wheel.
      Cheers,
      88M3 henna
      73T100C
      97 540\6-Gone
      2008 MINI Clubman S
        John,
        I don't think they'll work for you.
        I use 15mm spacers and they are too short.
        Jeff
        NASA GTS5 #945
          Thanks for clarifying Jeff!
          88M3 henna
          73T100C
          97 540\6-Gone
          2008 MINI Clubman S
            Jeff,
            Do you have the nuts to go with those studs? If so I'm interested, but I need to figure out if they would work with my 2 wheel setups:
            1) stock wheels (would center caps fit over the studs?)
            2) SSR Comps with 10mm spacers
            I'll try to take some measurements so I can figure out the answers.
            Thanks!
            Dominic
              pics of the RK's to [email protected]
              thanks
              Matt
                i'll take the studs if they come with nutz and the GC CABs too. i can paypal you asap
                they are not idiots.
                  Are the guibo's new?
                    Reelizmpro
                    >> No, they are used, but in fine condition, no tears or dry rot.
                    Eric
                    I'll take the studs if they come with nutz and the GC CABs too. i can paypal you asap
                    >> They don't include nuts. everything is first pay first own. contact me via email for additional information or to work out shipping
                    88M3ofDoom
                    >> links to pictures sent
                    Dominic
                    >> Nuts not included, will probably work with stock wheels, but I have no way to check for you. I can provide other photos with clearer image of ruler which could help you determine if they'll work for you.
                    Jeff
                    NASA GTS5 #945
                      coolant expansion tank - very good condition (white plastic) - $25
                      ICV -fully functional -$100
                      alternator bracket (12311284306) - $20
                      TPS $10
                      brake booster - $50
                      stock FPR - $10
                      5spd OD trans $499
                      coil $20
                      dipstick/tube $10
                      handbrake lever $10
                      fan w/o clutch $15
                      crank sprocket $50
                      740 motor mounts + 535 trans mounts - sold
                      Starter - sold
                      timing case - sold
                      Jeff
                      NASA GTS5 #945
                        Is the alternator bracket new?
                        -AJ
                        -'88 Henna Red-
                          nope, everything is used unless otherwise stated.
                          Jeff
                          NASA GTS5 #945
                            updated list
                            Air vents from outside dash locations - $15 pr
                            4.10 Differential w/101k miles, I swapped my MCoupe cover to another diff, so a new gasket will be needed. I will provide the new gasket uninstalled, so you can inspect everything before it goes together. - $350
                            new wheel studs - 60mm overall qty 20 -$25
                            TPS $10
                            brake booster - $50
                            stock FPR - $10
                            Euro 215 head w/ +2mm intake +1mm exhaust Supertech valves/ VAC custom 12k RPM springs/ bag of misc valves (I suspect at least one bent exhaust valve in #2 combustion chamber) $2100 as is or...
                            coil $20
                            dipstick/tube $10
                            handbrake lever $10
                            fan w/o clutch $15
                            crank sprocket $50
                            rear fiberglass bumper insert - pending
                            Ground Control spherical front control arm bushings in lollypop bracket - pending
                            Starter - sold
                            timing case - sold
                            5spd OD trans - sold
                            Jeff
                            NASA GTS5 #945
                              this list contains many parts that people have been asking for
                              Header flange for custom exhaust (used/ Evo sized) - $40
                              Blue silicone hose for carbon airbox (email for details)- $20
                              Ground Control spherical front control arm bushings in lollypop bracket - $150
                              new wheel studs - 60mm overall (nuts not included) qty 20 -$25
                              TPS $10
                              brake booster - $50
                              stock FPR - $10
                              16x8 BBS RK w/245-45 Kuhmo Victoracer (painted black - track wheels) $489
                              coil $20
                              dipstick/tube $10
                              handbrake lever $10
                              fan w/o clutch $15
                              crank sprocket $49
                              power window regulator and motors (both sides available) $149 ea
                              trunk carpet and side/ back/ front trim panels $99
                              Starter - sold
                              timing case - sold
                              NASA GTS5 #945
