FS: VAC 3/4" Roll Center Spacers
  • FS: VAC 3/4" Roll Center Spacers
    Almost new, one weekend of use. Great product, but I need the 1" spacer so these 3/4" units have to go. $100, SHIPPED!
    Christopher
    Christopher
    www.brmmotorsports.com
    Chris, I have the 3/4" spacer and wondering what your opinion is on them. What's the reason for the step up to 1"?
    I was considering the 1" but was told that 3/4" was plenty for most applications.
      Our application isn't like most. I've got to get the JP car lower, and the 3/4" isn't enough. The main reason I need the 1" (which is still going to be marginal) is because I've got to get the ride height correct with 245/40/17 R6s on a 17X9 Team Dynamics PR1s. It's an awfully big wheel/tire combo that increases the ride height quite a bit. 3/4" should be plenty for even the lowest 15" and 16" wheel/tire combos. The VAC spacer is very nice. I've just got to trade-up for the bigger unit.
      Christopher
        Would like to buy... PMing
          Chris I'm not sure if I read your post correctly but it sounds like you are using these to reduce your ride height?
          All these spacers do are reduce caster and correct the control arm angle - you would be correct on using a larger spacer for an extremely low car, but the spacer by itself will not affect ride height more than 1 or 2 mm.
          I'm not familiar with the rules of JP but my Turner JS kit rode pretty high due to the crash mounts up top - I switched to Vorshlag camber plates and now my 225/40R18s are tucked up in the fender.
            Brian,
            Chris only mentioned suspension height because it is the reason his tie rods are at a severe angle (more so than std lowering). Hence the need for taller ackerman/roll center spacers.
            Pat
              right on, I figured as much but wanted to verify
                Originally posted by m3pat2 View Post
                Brian,
                I think we are all on the same page now.
                PMs replied.
                SPACERS ARE SOLD!!!!!!!!!
                Thank you.
                Christopher
