ABS brakes malfunction
  • ABS brakes malfunction
    I have a 1990 M3 track only car..the abs works fine for about four to five laps..then the right front tire starts to lock up..I have changed all four wheel sensors but still have the same problem..any ideas..thks, Don Sweitzer
    I have an ABS module you can buy for cheap. No idea if it will help or not, but it came from a good, non-drashed car.
    02 M Coupe
      I've heard that if your wheel bearing is going, It could cause bad sensor readings.
