After a year of development I’m now ready to offer the S14 plug and play ecu setup to everyone, what you get is a megasquirt ecu mounted and wired up inside a stock ecu case utilizing the factory engine wiring harness and plugs. This unit is as plug and play as possible and is loaded with an s14 base line file which should get your engine started(tuning to match your engine is required). For those that don’t know what megasquirt is, it’s a DIY friendly programmable ecu that completely replaces your stock ecu and allows you full control over your spark and fuel tables VIA an Alpha-N tuning algorithm. You can completely eliminate your factory AFM, and gain some ponies, throttle response, and overall performance from your stock or modified s14. This is perfect if your running a carbon fiber air box or have built a 2.5 stroker motor. Your engine will still look completely factory and the installation is easily reversible if you ever wanted to return back to a stock ecu.
The typical installation requires the following wiring/modifications
• Mounting the trigger wheel to the stock crank pulley
• Mounting the VR sensor and bracket to the engine block
• Bolting on the variable TPS
• Wiring variable TPS into the stock TPS plug(directions included, only 3 wires to be wired)
• Wiring VR sensor into the stock Engine speed sensor plug
• Wiring air temp sensor into stock AFM plug and mounting sensor in the air inlet stream
• Wiring up wideband o2 sensor into the stock o2 sensor plug
Required extra components to run this ecu
• Crank pulley mounted Trigger wheel-recommend the 36-1 custom wheel from Lee Vuong http://www.s14.net/forums/showthread.php?t=34039
• VR sensor and bracket-recommend the ford sensor
• Variable TPS-Recommend the S54 TPS and adapter from Lee Vuong http://www.s14.net/forums/showthread.php?t=28707
• Air temp sensor-recommend the GM open element sensor
• Wideband o2 sensor and controller-recommend the Innovate lc-1(not needed if having the car dyno tuned, but necessary if tuning yourself)
Pictures using the eta ecu case
Pictures using the stock s14 ecu case
As a special introduction pricing I’m offering these ecu’s for $600(base unit with ms1 processor) a $45 ecu core charge is also required unless you send your old ecu upfront, if paying a core charge you will be supplied with an eta ecu case, which mounts and functions in all the same ways, just is cheaper to get ahold of. Each ecu is built to order so there is usually a 2-3 week turn around time depending on the # of current orders
Add on options
• PWM idle control to control your factory idle control valve-$40
• Electronic fan control to control an electronic fan to kick on and off at set temperature inputs-$10
• Distributor less ignition running a waste spark configuration-$40 The only additional hardware needed are the coils and plug wires
• MS2 Processor upgrade-$90 Features include faster processing time and larger tables
Add on options
