FS: Large E30 M3 Parts Inventory
  • FS: Large E30 M3 Parts Inventory
    BMW M3 E30 Parts
    All Prices Are Without Shipping
    1 – New FiberArtz Fiberglass Front Bumper - $300.00
    1 – New ATE Master Cylinder (34-31-2-225-505) - $150.00
    5 – New Tower Paint Spray Can (Diamantschwarz – Metallic) - $10.00 each
    1 – Slightly Used (3/4 – 7/8 full) Tower Paint (Diamantschwarz – Metallic) - $5.00
    1 – New Laso Water Pump (11-51-1-315-211) - $75.00
    2– Used OEM Reman Water Pumps (11-51-1-315-211) - $50.00 each
    1 – New Sway Bar Links (31-35-1-134-582) - $10.00 each
    1 – Used Sway Bar Link (31-35-1-134-582) - $5.00
    3 – Used Starters (all work) - $75.00 each
    3 – New Alternator Adjusting Bar (12-31-1312-137) - $15.00
    1 – Used Alternator Adjusting Bar (12-31-1312-137) - $7.00
    1 – Used Throttle Switch (0-280-120-301) – 25.00
    1 – New Bosch Oxygen Sensor (13058) - $75.00
    2 – Used Alternators (operational) - $75.00
    1 – ECM Computer Bosch (0-261-200-071) – I believe it to be a stock chip - $300.00
    1 – Stock M3 Steering Wheel - $100.00
    1 – Stock BMW Steering Wheel - $75.00
    2 – New Bosch Flywheel Pickups (0-261-210-002) - $35.00
    2 – Used Bosch Distributor Caps (03-241) - $25.00 each
    2 – Used Bosch Rotor Buttons (04-187) - $7.00 each
    3 – Used Bosch Ignition Coils {(00060)(0-221-118-335-740)} - $20.00/each
    1 – Used Bosch Fuel Regulator (0-280-160-249-000) - $20.00
    1 – S14 Bell Housing - $200.00
    1 – Stock Chip #1267355547 - $50.00
    1 – Turner Motorsport Chip #0710-3100 2.5L - $100.00
    1 – VAC Chip 228HP – 7000 RPM 2.5L - $100.00
    1 – New High Beam Headlight (63-12-1-385-817) - $40.00
    2 – New Individual Rod Bearing Sets – Federal Mogul (11-24-1-310-515) - $6.00 each
    1 – New Bumper Rubber – Right (51-11-1-904-686) - $30.00
    1 – Used Coolant Expansion Tank - $25.00
    1 – Used Oil Pump - $50.00
    2 – New Front Brake Rotors – Cross Drilled - $125.00 set
    2 – Used Front Brake Rotors (Good Condition – surface rust) - $20.00 each
    4 – New Front Brake Rotors - $40.00 each
    4 – New Rear Brake Rotors - $25.00 each
    2 – New Rear Brake Rotors (surface rust) - $15.00 each
    1 – Used Crankshaft (good condition) - $400.00
    1 – Used Oil Filter Mounting Head - $100.00
    1 – New Oil Filter Mounting Head w/new filter - $200.00
    1 – New Set of KFP Magnum Brake Pads P42A Gold (KFP396) - $125.00
    1 – Used OEM Brake Booster - $50.00
    1 – New Set H&R Wheel Spacers 15mm - $70.00
    1 – Used Set H&R Wheel Spacers 15mm - $50.00
    1 – Used Set H&R Wheel Spacers 12mm - $50.00
    2 – Used Stock Lower Oil Pans - $200.00/each
    3 – Used AFM’s - $80.00 each
    1 – Used Power Steering Pump w/Reservoir & Hoses - $80.00
    1 – Used Oil Cooler w/Hoses (Great Condition – Looks New!!!) - $150.00
    2 – Radios with codes (1-with finger slide/1 – without) - $50/each
    1 – 6 Disc CD Changer - $50
    4 – New Hoosier R6 225/45/15 – Heat cycled on Kosei K1 - $1300.00/set
    4 – New Hoosier 84H 205/50/15 on Kosei K1 - $1300.00/set
    4 – Used Kumho V70A 225/50/15 ½ life left on Kosei K1 - $800.00/set
    2 – Used Hoosier R6 225/45/15 (no track life left) on Kosei K1 - $125.00/each
    1 – New Hoosier R6 225/45/15 on Kosei K1 - $325.00
    16 – New NGK KR8AI (5477) Spark Plugs - $4.00/each
    28 – New Champion 905 – RA4HC Spark Plugs - $2.00/each
    3 – New Beru Ultra 12-5DU Spark Plugs - $4.00/each
    4 – New Bosch Super X5 DC Spark Plugs - $2.00/each
    1 – New Power Steering Adj. Bar (12-31-1-719-992) - $3.00
    1 – Used Upper Oil Pan - $ 200.00
    5 – New Hawk Brake Pads HT Compound/Rear (HB227S.630) - $100.00/each
    7 – New Hawk Brake Pads HT Compound/Front (HB192S.620) - $100.00/each
    2 – Valve Covers - $250.00/each
    1 – New Set of 4 Bosch Fuel Injectors (0-280-150-803) - $500.00/set of 4
    2 – New Sets of 4 VAC 2.5L Stroker Injectors - $500.00/each set of 4
    1 – Used Fuel Rail with Stock Injectors - $150.00
    1 – New Support Bracket/Left (41-14-1-943-223) - $12.00
    1 – New Support Bracket/Right (41-14-1-943-224) - $12.00
    1 – Used 3qt. Accusump Kit - $200.00
    1 – FAST Cooling Suit/Large - $200.00
    8 – ½ inch Roll Bar Padding (Jegs) - $1.00/each
    1 – New Earth Ground Strap (12-52-1-285-011) - $12.00
    2 – Used Rear Bilstein Shocks (2027-HO) - $35.00/each
    2 – Used Front Bilstein Shocks (0335-HO) - $35.00/each
    1 – Set of Sparco Seat Brackets - $25.00/set
    1 – New Hood/Trunk Badge (51-14-8-132-375) - $20.00
    3 – New Brake Anti Rattle Springs (34-21-1-157-046) - $3.50/each
    2 – New Brake Anti Rattle Springs (34-11-2-226-203) - $3.50/each
    2 – New Alt. Adjusting Bar Nut (12-31-1-273-639) - $2.50/each
    3 – New Brake Light Switches (61-31-8-360-420) - $6.50/each
    2 – New Radiator Caps (17-11-2-227-683) - $8.00/each
    3 – Used Radiator Caps (17-11-2-227-683) - $4.00/each
    1 – New Exhaust Hanger Rubber (18-21-1-712-838) - $3.00
    1 – Used Clutch Fan (11-52-1-310-520) - $100.00
    2 – Used Auxiliary Fans (64-54-1-381-633) - $150.00/each
    1 – Used Air Plenum (11 61 1 310 786) - $250.00
    1 – Used In Tank Fuel Pump - $30.00
    1 – Stock Cylinder Head - $800.00
    2 – Cam Box/Trays (11-12-1-308-424) - $400.00/each
    1 – Air Filter Box (Intake) - $30.00
    1 – Stock 46mm Throttle Bodies - $225.00
    1 – Used Radiator Line (11-53-1-310-664) - $125.00
    1 – Pair of Motor Mounts - $50.00
    3 – Used Window Switches (61-31-1-381-205) - $7.00/each
    1 – Used Defroster Switch - $7.00
    1 – Pair High Beam Headlights w/Frame (left & right) - $50.00/pair
    2 – Rear Speakers (no covers) - $5.00/each
    1 – Eibach Spring Kit (2017.101/2017.002) - $200.00
    1 – Engine Wiring Harness - $75.00
    2 – Timing Case Covers (11-14-1-309-184) - $75.00/each
    1 – Bowl Reinforcement (11-14-1-277-030) - $35.00
    1 – Used Oil Separator (11-15-2-241-124) - $10.00
    1 – Used Sunroof Regulator (54-1-21-874-871) - $20.00
    1 – Used Window Regulator Left (51-32-1-904-611) - $20.00
    1 – Used Window Regulator Right (51-32-1-904-612) - $20.00
    1 – Used Washer Level Sender (61-31-1-388-578) - $5.00
    1 – Set Used Intake Manifold Gaskets (Good Shape)(13-54-1-318-318) - $30.00/set
    1 – Used Fuse Panel Cover - $5.00
    1 – New Driveshaft Centering Sleeve (26-11-7-526-611) - $5.00
    35 – New Wheel Lugs – Bronze - $1.50/each
    33 – New Wheel Lugs – Silver - $1.50/each
    That's nuts. What are the specs on the k1's?
      The list shrank tremendously just before posting as a few guys purhased seceral items..
      Specs? Unsure what you want to know.
      All the wheels are used but in very good condition.
      total of 5 hoosier r6's brand new heat cycled. never put on the car yet.
      totaol of 4 hoosier 84H rain tires, brand new, never on car.
      4 kuhmos 1/2 life left
      2 hoosier r6's - little to no life left
        Are the Kosei's 15x8" ?
        -AJ
        -'88 Henna Red-
          yes all the kosei's are 15x8
            Fiberartz bumper - sale pending
              Stock chip - pending
                stock chip.... SOLD
                  wiring harness...... pending
                    engine wiring harness and fuse panel cover.... SOLD
                    Thanks to all for the purchases thus far!!
                      how many miles on these? thanks
                        Could not tell you... I inherited all these parts and cars I'm selling... I wish I had more info for you. All I know of them is they came off them M3 when it was converted to a track car.
                        Sorry thats all I know about them.
                          pm sent
                            I know this isnt listed, but do you have the plates that connect to the tie rods/ca's on the bottom of the front struts?
                              Is the front bumper still for sale?
                              1989 M3 M3T #99
                              1988 M3
                              1988 M5
                              1986 Euro M6
                              1976 2002
                              1972 3.0 CSL Group 2 "Flying Stuck" recreation
                              www.vsr1.com
