Custom part - Interior light delay w/ auto dimming
It's actually a function of the way BMW wired the stock relay into the car, and not my unit. Since this unit is plug and play replacing the stock relay, that's the way it works too. All the lights work as normal, except the delay is triggered by the driver's door.
If you would like both doors to trigger it, you would need to run one wire from the passenger door pin switch to the driver side door pin switch. Leave the factory passenger door wire unplugged, secure it out of the way. That's it.
Most people like that the dimming only work on the driver's door - so it not an issue for most - but you can still change it down the road if you would like.
