<FS> 2.7l crank and connecting rods
  • <FS> 2.7l crank and connecting rods
    I have to change my build schedule on this thing and I'd rather not sit on these parts. I have a 2.7l crankshaft (brand new, never fitted or anything) and the corresponding connecting rods (also brand new) that I'd like to sell. Parts are available now, I'm not selling my spot in line for the next build.
    Asking $3500 for the crank and $1750 for the rods, plus shipping.
    Cheers.
    Jack
    You have a PM !
      replied.......
      Jack
        Sweet! Good luck with the sale, if I had it... It would be done.
          Can regular s14 length connecting rods be used with the 2.7 crank?
          www.ZeppieriMotorsport.com
          E30 M3 Rebuild Thread
            I'm pretty sure longer rods would have to be used, not enough to be done with just pin placement on the piston... rod ratio, ya kno
              Although not as optimal, I think you can use std rod length. Obviously the pistons will have to be custom.
                Right now this is meant to be used with a longer than stock rod. Cheers.
                Jack
                  Jack
                    bump!
                    Jack
                      Jack
                        bump.
                        There are some potential options for 144mm rods. Cheers.
                        Jack
                          What is the stroke of the crank?
                          1988 E30 M3 S38
                          1970 E10 2002 S14
                            stroke is 94mm.
                            Cheers.
                            Jack
                              If any of you want this crank with 144 mm connecting rods, I have a brand new set of Arrow's
                              Regards
