S14 Engine & Box
  • S14 Engine & Box
    For sale supercharged s14 + dog leg box.
    Engine rebuilt (never yet run) with forged low comp pistons, mls gasket, arp bolts. Comes with new unused paddle clutch, throttle bodies, alt, starter motor. I bought built up as it was meant to be a turbo engine.
    Period albrex supercharger http://www.albrex.com/german/ with mounting brackets and pulleys, currently mocked up using washers as spacers so pucker spaces need machining with correct length bolts. Also the crank pulley could do with being a couple of teeth shorter to up the boost due to the low comp engine, something turbosport where going to do for me.
    http://www.turbosportraceparts.com/a...g/Pulleys.html
    Also comes with a DTA e48 ecu with mill spec loom and uprated injectors (cleaned and flow tested), s54 tps adaptor for the throttle bodies and a crank trigger set up.
    The gear box is a fresh rebuilt 265 dog leg box by JC racing
    Also comes with a set of custom engine mounts that put 2" back in the e21 using a 6 cyl subframe (requires the subframe to modified for clearance)
    Looking for 7k for the lot and you collect from Edinburgh, or courier at your cost
    Holy shit.. I wish you were here in the States..
    1988 Diamantschwarz/Black
      Wow! Now that's a sick and rare combo!!! GLWS
      Castro Motorsport
      12600 Sherman Way, Unit C
      North Hollywood, CA 91605
      (818) 765-3606
      The Purple ///Monster Build:
        Would you be interested in splitting? I'm interested in the gearbox, bellhousing etc. and I'm only in Glasgow. This could be perfect.
        Let me know.
