I finally got around to replace my 4-pt harness with a 6-pt one. Before I drill the holes for the eye bolts, I want to check with you folks if I have the mounting points right. See pic below. The locations of of the brass rings are where I intend to drill. The left-most and right-most positions are for the lap belts (left one is already threaded from the factory). The 2 middle ones are for the sub belts. They're about 6 inches behind the middle opening of the race seat, 4 inches apart. The shoulder belts will be mounted on the bolt-in cage.
Does it look right to you guys?
TIA,
-Fred
TIA,
-Fred
