I probably need to replace my stock aluminum front control arms (its been more than 2 years). They are expensive. I have stared at Jakes DTM tour of the DTM front suspension over and over again and it makes me want to make my own fully adjustable lower suspension. But I know it would take me quite a while before I was happy with it and it might be cheaper to buy something already available. The only thing I have found is the AKG kit: http://www.akgmotorsport.com/catalog...Control%20Arms
They have a 1200 and 1800 dollar version. Has anyone tried this? I wish they would have used a material other than aluminum. I also found some peoples at home solutions:
http://www.e30tech.com/forum/showthread.php?t=105209
None of these designs is really as ideal as the DTM design which involves modifying the front subframe for the spherical bearing mount and moving the attachment points higher into the chassis to compensate for the lowered car. I'm curious to hear if anyone went to the trouble of doing a full DTM style lower front suspension or if anyone has tried the AKG kit (or another one that I don't know about).
Gustav did a nice write up I've been looking through as well: http://www.e30m3project.com/e30m3per...arms/index.htm . Here he talks about some of the compromises made on the design so that he could have the turning radius desired in a street car. That compromise is evident in the AKG design. They actually don't look that complicated. it's a couple 4130 tubes that are threaded with spherical bearings in each end. But of course actually creating it all and within the tolerances required to make it an improvement over the stock control arm isn't that easy of a task.
