Ditched my E90 for an '88 DS
  • #76
    Here are the photos of Jon's progress. I wish I could participate but I am stranded in Atlanta due to flight cancelations.
    Oil pans have been installed and re-sealed with liquid sealant.
    IE steering coupler installed and subframe back in position. Pilot bearing and rear main seal have been replaced.
    We (read: Jon) attempted the 'pack with grease' extraction method for the pilot bearing but an Autozone rental did the trick.
    My intake cam was one tooth advanced, or perhaps retarded, I can't tell by looking at it. Jon loosened things up and straightened it out.
    Before
    After
    Everything else back where it should be.
    Front shocks have been swapped, once I receive the new upper strut mount bushings we'll be ready to get the springs back on and finish that component.
    Axle cleanup and re-boot efforts ongoing.
    Next steps: replace header studs and nuts with the kit from Turner; get the flywheel machined to Evo spec, get all bearings and bushings replaced, and start putting this baby back together! It's going to be a good new year.
    1989 Lachs
    1988 Lachs - sold
    1988 DS - sold
    Bay Area M3 FB group
    • #77
      Some more progress today.
      Transmission seals (input shaft and rear seal) replaced, hopefully the days of weeping are over.
      New clutch fork, new spring, new plastic pins (forgot what they're called).
      Upper strut mounts arrived so preparing to reassemble the front struts. Various bits and bobs
      Front strut assemblies back together. New Koni shocks, new rubber spring seats where needed, new bump stops, new shock upper mounts.
      Moving in the right direction... reassembly.
      Tomorrow the flywheel and everything with bushings is headed to the machine shop to be resurfaced / lightened / pressed out.
      1989 Lachs
      1988 Lachs - sold
      1988 DS - sold
      • #78
        Tip for the pilot bearing: wet paper. Rip up pieces of paper and soak them in water. Then stuff them into the pilot bearing and eventually it will come out nice and easy.
        • #79
          Good tip, we/he was able to get it with a rented tool. The other trick I heard was bread (doing the same thing as the paper and grease). We almost went for a nice loaf of sourdough...
          1989 Lachs
          1988 Lachs - sold
          1988 DS - sold
          • #80
            Looking good Pall. I'm glad to see you put my shocks to use. I can't wait to see it with the LMs that Chris built.
            • #81
              Thanks! I can't wait to get back on the road.
              Jon has pressed in a new bushing to my shifter rod and machined it to match my shift selector rod exactly. He also turned some delrin down for the joint on the other side. This man is a tight-fit fanatic!
              I finally picked up my personalized plate from the DMV. California is re-issuing its "legacy" plates from the 60s. I wouldn't usually go for this thing but I was surprised to see this plate was available and decided I'd try the black on black.
              On Friday I dropped off my flywheel to be lightened to Evo spec and resurfaced, I hope to receive it back this week. All bearings and bushings are also in the process of being pressed out / swapped over.
              1989 Lachs
              1988 Lachs - sold
              1988 DS - sold
              • #82
                very nice!
                • #83
                  Reassembly continues. The rear end is coming back together, the subframe is back in place.
                  Axles have new boots. Cleaning out the old grease was not the most fun thing
                  Splines cleaned up a little bit
                  New wheel bearings to receive them
                  In process / installed and torqued. Axles done
                  Shifter assembly back together and feeling good.
                  Driveshaft overhauled with new center bushing.
                  New fuel hose
                  Diff bushing
                  Subframe bushings
                  Trailing arm bushings
                  Spring pads and OE springs back in place
                  Front... nothing new since the last update
                  New license plate, really happy with it. My driver window stopped working around Thanksgiving so we dug in and diagnosed a bad motor.
                  Transmission awaits lightened flywheel.
                  Only a few major items left at this point - the flywheel was supposed to be done this week, but we'll have to delay a bit. When that returns we reinstall the transmission, replace the header studs, reinstall driveshaft, exhaust, fill it with oil and brake fluid, and get it back on its wheels.
                  1989 Lachs
                  1988 Lachs - sold
                  1988 DS - sold
                  • #84
                    The flywheel is back. Resurfaced, lightened to 12.5 lbs, and balanced. Hopefully this means I'm done buying parts for this job! Planning on making big progress this weekend with Jon.
                    1989 Lachs
                    1988 Lachs - sold
                    1988 DS - sold
                    • #85
                      This car is coming along very nicely. Love following your progress!
                      • #86
                        Thanks CourtM3!
                        Today was a big step - the transmission is back in the car. Jon and I worked a long day and we plan to reconvene tomorrow and get this thing finished up.
                        One last look at the main seal area
                        Lightened flywheel installed with shorter bolts, as the bolting face was machined down to Evo thickness. Threadlock used on the bolts per the recent SIG mailing list chatter
                        I ordered new pressure plate bolts but they were longer than what we removed; after some confusion about spacers we concluded that, while some M3s seem to have these spacers, mine did not and would be fine without them.
                        Extracting header to address some missing nuts and studs
                        Turner Studs and new gaskets
                        Header done. These were annoying to reach
                        Transmission is back in the car! This was straightforward, but the starter bolt/nuts at the top are a royal pain. They were annoying to remove, they were more annoying to reinstall.
                        Tomorrow we finish the shift linkage, driveshaft, exhaust, add oil, bleed the brakes, and hit the road!
                        1989 Lachs
                        1988 Lachs - sold
                        1988 DS - sold
                        • #87
                          Are you installing the LMs yet ? How is the alcantara holding up on the steering wheel ?
                          • #88
                            The LMs aren't going on yet, I wanted to get this job done first before fitting nice wheels. My wallet still needs to recover from this project and the holidays so it will be a little while before I get tires on the wheels, and then I'll need to get some springs to get the ride height right. The alcantara is holding up okay, but I don't know that I would buy it again. Leather would last much longer.
                            1989 Lachs
                            1988 Lachs - sold
                            1988 DS - sold
                            • #89
                              I drove my car for the first time in 2 months today!
                              Guibo reinstalled
                              New clutch slave cylinder and braided line installed. The old one was shot and causing my terrible clutch feel / engagement
                              Replaced the clutch master because hey, why not. This little fitting was a pain in the bum to swap over.
                              Jon got tired of waiting to finish my project, and bought himself another project
                              I was missing the header bracket - new one installed
                              Driveshaft center support reinstalled and torqued
                              Head shielding
                              Exhaust back in
                              Jon didn't like an ugly weld on my center section and went after it.
                              Eisenmann sport
                              Jon goes after my trunk trim
                              With everything buttoned up, we added oil, bled the brakes and clutch, and started it up. After a short smoke show from the PB blaster-covered header we pushed back for a shakedown drive. The car feels SO much better. Previously I was crashing across the road, hating the clutch, hating the shifter feel... really not loving the car. Now it feels as it should. The clutch is light, the lightened flywheel revs more freely, the shift action is tight, and I can't even begin to describe the improvement to the handling and ride quality. Night and day. The Konis feel very well-matched to the stock springs.
                              We have a couple of issues to troubleshoot before I bring the car home - the reverse lights aren't working and pressing the clutch makes the brake lights go on, which is not ideal. Probably a mixup somewhere in the pedal area from our master cylinder replacement. Otherwise the car feels absolutely amazing. Thank you Jon, I could never have done this without your help.
                              1989 Lachs
                              1988 Lachs - sold
                              1988 DS - sold
                              • #90
                                Back on the road! New Koni struts have propped the front ride height up a bit.
                                1989 Lachs
                                1988 Lachs - sold
                                1988 DS - sold
