Would a transmission fall out?
  • Would a transmission fall out?
    I've never even looked at the tranny mounts before, but the other day I noticed that a lower nut for one of the bushings was loose. I tried to tighten it and the whole bushing rotated under the transmission. This led me to notice that there are no nuts on top holding the tranny to the bushings and lower mount. So the transmission is just sitting on top of the bushings with nothing holding it there. Is this correct? It doesn't seem like it would be, but I thought I would ask. Thanks.
    Ben
    It won't fall out but the excess movement from the engine torquing over to the right side will damage the Guibo after a while, and eventually , the center drivshaft bearing.
    I'd better check mine.
    Thanx for askin'
      There should be nuts on top of the bushes.
      Steve
      Scottish Cecotto
