ANYBODY HERE USING THESE SPRINGS? STREETABLE? I DON'T DRIVE THE CAR EVERYDAY. ANY INPUT WOULD BE APPRECIATED! TIA
H&r Race Springs
get HnR gruppe G springs if you can... they are very stiff, but ride height is very nice and it handles VERY well.... if you get either the race spring or the gruppeG springs, i would HIGHLY recommend that you get the TMS J-stock shocks as they are designed to be used with a performance spring.
ted1990 e30 m3
The H&R Race springs are really quite streetable for relatively smooth suburban streets. If you're living somewhere the roads are especially bad they might not be ideal. They don't drop the car a tremendous amount. Here is a pic from when I was using them, I've since moved on to a more track friendly setup.
they lower about the same... if you are looking for springs that lower your car a substantial amount from stock, you won't find them unless you go H&R Gruppe G... contact motorsport imports, they have them. These springs will seriously lower your car. But... either way you go you NEED to get the TMS j-stock shocks. these shocks are physically shorter, and valved for the very aggressive spring rates. I searched forever trying to find a spring setup that would actually lower the car noticeably... after everything i've been through, i think coilovers are un-questionably the way to go as far as your suspension setup. Ground Control has a very nice setup, but H&R from what i've heard is a very nice setup also... HTH
ted1990 e30 m3
Anyone running H&R Race / IE Stage 3's in the Northeast?
I'm possibly moving up to Long Island, NY - looking at a set of springs for my M3, to go w/ the brand new short top-adj Koni's I have already.
How streetable is this setup, in the area?
Thanks!-AJ
-'88 Henna Red-
Originally posted by UofOm3 View Postthey lower about the same... if you are looking for springs that lower your car a substantial amount from stock, you won't find them unless you go H&R Gruppe G... contact motorsport imports, they have them. These springs will seriously lower your car. But... either way you go you NEED to get the TMS j-stock shocks. these shocks are physically shorter, and valved for the very aggressive spring rates. I searched forever trying to find a spring setup that would actually lower the car noticeably... after everything i've been through, i think coilovers are un-questionably the way to go as far as your suspension setup. Ground Control has a very nice setup, but H&R from what i've heard is a very nice setup also... HTH
ted
The H&R Race lower the car about 1.5 inches from stock, and it's a noticeable drop. I don't think you'd want to go much lower on a street-driven car.
The TMS J-stock shocks are great, but would make for a punishing ride on the street.Last edited by dreeves; 04-02-2007, 02:16 AM.
I've ran H&R Race springs w/Bilstein sports for about 6 years now and they're great for the street. I used to run Eibach springs and hardly noticed a difference. i was very disappointed with the drop. So I went with H&R Race springs which gave it a nice drop except not enough rake so the front looks too high compared to the rear. I just removed the 1/2" thick upper spring pads yesterday and the front end now sits perfect! I love it! it makes a big difference.
I'm running without the spring pads. BMW sells thinner ones though if you must have them. I'm thinking about maybe getting the offset strut bearing mounts and deeper spring hats.
none that I have noticed. BTW, the spring pads I had on my car were very thick...at least 1/2". The car now looks perfect without them.Last edited by Reelizmpro; 04-02-2007, 08:46 AM.
