As some of you may remember, I spun a rod bearing two months ago and decided the best (easy & cheap)
way to get my car back on the road was to buy a used motor and do a swap. But, it quickly turned into more...
Here's a list of the things I've replaced:
- guibo
- tranny seals (input, output, shifter)
- tranny fluid (redline)
- tranny mounts
- shifter carrier bushings (uuc)
- shifter selector rod knuckle
- tie rods
- sway bar links (ground control)
- oil cooler
- control arms (aluminium)
- control arm bushings (powerflex)
btw, the powerflex bushings require a bolt to be drilled into the control arm brackets,
to stop it from spinning. Since the CA bushings are known to squeak, I drilled a hole all the way
through to the control arm, and dremeled a groove inside the bushing.
Now, I can grease the bushing from the outside!
about the swap...
the old motor is ready to be pulled out, I just need to rent a cherry picker hoist.
then I can pull the old flywheel/clutch off and install it on the new motor.
btw, if I can get enough, I'm just going to sell the old motor as is.
does anyone know what a 150k mile, stock S14 with recently rebuilt head,
and a spun bearing would go for? If not, I may just end up parting it out.
the new motor is a stock, 100k mile S14 that I bought from VAC. the previous owner pulled it out to
do an M50 swap. It's a very clean motor, evo wires, s52 chain tensioner... But since it has 100k miles,
I've decided to replace the rod bearings, rear main seal, crank gaskets, and upper/lower oil pan gaskets.
hopefully, I should have a running car within the next week or two.
just in time for petersburg prosolo!
here's a pic of the new motor:
- guibo
- tranny mounts
- tie rods
- oil cooler
about the swap...
