engine compression question
  • engine compression question
    All,
    I searched but couldn't find anything this specific.
    As I understand the actual compression #s are important but more importantly is their consistency across all cylinders.
    I found a car that has a compression of
    1. 235
    2. 232
    3. 235
    4. 205
    While they all are way above the average, I am concerned about the last cylinder because it basically has a 30psi difference.
    What's you take on this. Is this gonna lead to some sort of a problem?
    BTW I do not have the leakdown numbers handy
    zhpregistry.net
    Can you repeat the test? Was the battery getting weak on that last cylinder? I would bet that 99% will test the front cylinder first, since, hey, it's # 1 right? If you can repeat the test do #4 first, see if that changes anything.
    Put some oil, whatever's in the crankcase, into #4 (do a "wet" compression test. If the # comes up, that indicates that there is an issue with the rings in that cylinder. I say "issue" rather than "problem" because maybe they are stuck.
    I would follow up with a leakdown test if at all possible.
    These compression numbers don't inspire me to run like hell away from the car, but I would do some more investigating.
    Don't spend your last dime buying a car that may be needing engine work in the near future.
