power to ecu
  • power to ecu
    Months agao I removed fuse box to accomodate a roll cage. Fast forward to now, I am trying to figure out how to provide power to the ecu. I replaced stock ignition switch with an aftermarket panel. I have supplied the green wire power (pin #7 on the c101 the power to ign coil and main relay) via ignition switch. I have verified with volt meter and the main relay is getting power. The engine now cranks. I was under the impression that if power is supplied to main relay it can then provide power input to the ecu. However when testing the pins on the ecu, none were showing any power. By the way, no wires were cut from the engine harness. Am I missing something???
