Dead pedal install
  • Dead pedal install
    Hi,
    Found this THREAD through 'searchie' but I am still not sure how to remove the speaker panel under which the dead pedal should be mounted. :lostme:
    Thnx, Chris
    Not a problem. First remove the phillips screw on the panel. Then remove the undercover on the drivers side, underneath the steering column. You will then see 2 10mm (?) bolts going thru the hood release bracket and into the top of the speaker cover. Remove those two bolts, the pull the door lining up and remove the panel. Be careful not to break the bottom part. OK, once the panel is out, turn it over. On the back you should see a diagonal line impression in the plastic. You need to cut along this line in order to fit the factory M dead pedal on right. If you don't cut it it will be hard to align all of the screw holes when you put everything back together and things will be off. The other end of the pedal mounts where the clutch pedal stop is.
      Thanx !
      Anybody has the PN for the longer clutch stop.
      After installing the EVO3 dead pedal the 'original' clutch stop
      is not long enough to mount it firmly :S (and being a plastic screw
      does NOT help either)
      Thnx, Chris
        Good time to install an adjustable clutch pedal stop like the one UUC has or you can make your own.
