Originally posted by kiko
View Post
Thanks for the advice!
Im in the process of removing the subframe and fuel tank. I've decided to leave the rear beam in as I had a terrible time trying to get the same one out on my 318iS a couple of years ago. The subframe bushings wound up being hopelessly seized and I had to break them off and drill out the rest. Seeing as I don't want to do that again, I will leave the rear beam in place, remove the trailing arms and once the fuel tank is out I will grind it clean. Then I will use POR-15 and put atleast three coats on. Nothing gets through that stuff and it will be jet black. Same for the trailing arms - they are in very good shape with almost no rust. I dont have access to a lift so its all very hard work.. but here is how my 318iS subframe turned out:
Before:
After:
I'll get some pics posted as I go along and post the progress but I wont get much more done till the 17th as Im swamped with work....
