That is normal input shaft bearing noise. My car did it when I got it at 113K, and it still sounds the same at over 180K. I would not use anything but Redline MTL in the transmission. Thicker oils may quiet the rattle somewhat, but shifting will suffer, especially when cold. IMHO, there is nothing better for Getrag synchronizers than MTL.
This is not a clutch problem, because the release bearing should not be turning when the pedal is out. When my clutch went out, the noise increased when the pedal was depressed, due to the failing release bearing.
