Finally bought WBO2 for Alpha N
    Where did you install your WBO2 sensor? After the header joint, right before the cats? (or resonator if you have no cats). I understand the stock header location in the crossover pipe is too close to the exhaust ports. Is this correct?
    Alles Beste!
    B. Wheaton
    Register your E30 M3!
    http://www.bmwmregistry.com
      I've been running mine in the stock (Sport Evo) header location for about 12 years now....no issues.
        I used the stock location and a "heat sink bung adapter"
        http://www.innovatemotorsports.com/x...roductid=16148
        Maybe overkill, but seemed to work ok.
        -chris
        1988 M3
        2007 Lotus Exige S
          Curious... Chris, I could barely get the O2 sensor in there as it was - I can't imagine adding any height, but I can see that this is a good idea.
          I have the 50/50 rally header. I can't remember where the "stock" location was on my old header.
          My O2 bung is located here:
          Alles Beste!
          B. Wheaton
            Looks like the 2.3 and SE stock locations are farther up.... I guess it's good news for me that mine is farther down. They recommend 18" or so.
            Sport Evo
            2.3l
            Alles Beste!
            B. Wheaton
              Yeah on the stock header its farther up and also angled such that its not perpendicular to the collector so the extender fits. I'm actually switching to the same header you have and was planning on placing the bung in the same place you have. If that doesn't work I did have a bung added to a VSR center section at the crossover for Plan B.
              -chris
              1988 M3
              2007 Lotus Exige S
                Have your welder do a test fit/mock up or two so they can angle the bung over to the driver side a little. It makes a night/day difference in ease of fitment.
                Alles Beste!
                B. Wheaton
                • #23
                  Brandon, do you have a pic where you placed yours? I do not want to run in NB sim mode. Rather install a second bung.
                  • #24
                    Finally finished my additional 02 Bung install today and the LC-2 is working like a champ! Installed it on the X-pipe crossover.
                    • #25
                      WB02 AFR OEM Look by George G.
                      • #26
                        Are these still available?
                        Thomas
