Alternator exciter wire mixup
  • Alternator exciter wire mixup
    Hey all,
    I was replacing my alternator today with a new Bosch unit from turner. My previous battery was really old too so i replace that with a new one. After getting to the part where i hook up all the wires to the alternator, i had a momentary lapse and accidentally hooked up the 2 blue exciter wires to the positive large B+ lower stub along with the red large positive wire. So all 3 of those wires (2 blue and 1 red) were hooked up to that B+ pole. Ground was attached to the normal spot with the short 10mm bolt.
    Then i hooked the battery up and immediately, with the car off and no key inserted, i get a battery light on in the dash. So after realizing the error of my ways i reversed the wiring and put the 2 blue exciter wires in their proper location on the upper, smaller 'D+' pole.
    I have yet to start it yet because i fear i may have damaged something. Would i have damaged the voltage regulator of the alternator or something else with having the exciter wire incorrectly hooked up and powered on this way?
    thanks
    I think you're Ok. The exciter wire is merely a 12V load (the bulb in the dash cluster) which causes the regulator to start putting out 13.9V. I believe the 12V from the battery back-fed thru the exciter wire and illuminated the light on the dash. I presume the light did not go on once you hooked the exciter wire to the proper lug? I'd say start it up.
    Ron ///Man
    • '89 M3 M3T / ITR Club Racer
    • '94 Spec E36 - Eh....
    • '09 M3 - Tarmac Terrorist
    • '07 530 Xi - Highway Star
      Agree with everything Ron said. I'd hook it up and start it.
        Thanks guys, hooked it up and it started up fine.
          Great to hear!!! Enjoy!
          Ron ///Man
            Hey, don't mean to hi-jack your thread, but since you already resolved it I am going to anyway :-)
            I need to replace the red wire on my alternator, as it is visibly cracked. Can anyone tell me what this wire is for? Does it run to the starter? I looked all over realoem, and can't find the wires connecting to the alternator in any diagram. Will I be able to replace it by just pulling the alternator, or will the intake manifold need to come out too? If anyone has a part # for it, I would greatly appreciate it too. I just bought BavRest's 4-wire ground kit, and when I saw this decided I wanted to wait to pull the alternator to do the alternator ground replacement until I have this wire too. Thanks!
              That wire is a part of the engine harness and is not available separately. I believe it is the alternator output which goes back to the battery junction connection on the firewall and also to the starter and a few other things that get power at all times. You are going to want to remove the plenum to access it. It's a big sucker, ETM says 10mm2 or 8 AWG.
              -chris
              ETM:
              http://www.bimmers.com/m3/troublesho...30%20M3%20ETM/
              some pictures of the harness out of the car:
              Alt connections and Oil Temp and Pressure sensors by chris tsay, on Flickr
              1988 M3
              2007 Lotus Exige S
                Damn, that is what I was afraid of! Thanks for posting.
                  I would get some red 3M Electrical tape from Home Depot and do a nice neat job
                  of re-insulating the wire. I've done this to several cars . I think it would be not so
                  easy to replace it.
                  Ron ///Man
                    Its no so bad to change it, cut the terminal off the alternator end and soft solder the new cable (just the end) to the new cable get a heat gun to make the sleeve baggy and gradually you can pull it through.
