S14 with life of its own, then no start
  • S14 with life of its own, then no start
    Arrgh..
    Engine runs steady at 900rpm idle , and will do so indefinitely.
    But then will suddenly without provocation fish between 1900 and 2500rpm , erratic / quick successions .
    Some times it will return to normal, and contine unphased.
    Others it will not.
    If i kill ignition when it has the erraric idle, i cannot start it again.
    Smells very heavy with fuel on turnover.
    But will spring to life again if left long enough.
    Problem happens from cold or hot, after long or short drive.
    Please any assistance is golden.
    Andrew
    I thank god for every day i'm on this earth,
    with an E30M3
    Ok, search helped..
    Please can anyone confirm the CTS for the ecu is the 2 pin sensor , pn 13621709967
    with an E30M3
      Sensor changed.
      The old sensor measured very similar to the 3 new ones i bought to test.
      So not overly confident it's that, but will report after a prolonged testing period.
      with an E30M3
        Andy, I had a nightmare caused by two bad Bosch CTS. Original one failed and the new OE replacement failed as well but not initially. Symptoms were as you described, erractic high idle and eventual flooding which caused a no start condition. Clean plugs solved the symptom but not the problem. A new CTS is a good start but keep an eye on it and check the resistance at different temps to make sure they are within range for that temperature. My mistake was measuring the new TPS once and calling it good without giving it a second thought.
          Hi! Thanks for responding,
          I read i beleive your post on the cts , which was why i bought 3 to test,
          Normal room temp at 1900-2000ohms , 40degr. Cel. at 800 ohms
          But the problem was periodic, so a good measurement of the oe sensor wouldnt be 100% definitive.
          Ill have to wait until it happens again..
          But thank you for helping me,
          Regards Andrew
          with an E30M3
            Sorry late into this thread, obviously you figured out to point your finger at the CTS, but please do not discount the wiring back to the ECU that goes to the CTS.
            One thing that will start happening more and more often in these cars as they get older is these nearing on 30 year old engine harnesses will start to potentially become a problem area.
            Especially on that right side of the engine near the header. If you replace and its still doing it meter out those CTS pins back to the mass connector on the ECU
              Hi Jimmy, thank you!
              Yes i will have a look if needed , but i hope not.. I have having to pull stuff apart.
              The manual states (1364-1 picture number) pin 13 from ecu to cts.
              So ill have a fish about from the plug and see if there is matching resistance to mass.
              Thanks again guys
              with an E30M3
                Just un update,
                The CTS did fix the issue, and since change has not happened again
                with an E30M3
