coolant overflow hose holder- part #?
  • coolant overflow hose holder- part #?
    Does anyone know the part number to this clip holding the coolant overflow hose?
    here https://www.ecstuning.com/b-genuine-...g/17112225396/
      Not the hose, the clip that holds the hose
        Thankfully, I finally found the part number. Its only on early models which is why I couldnt find it before
        http://www.realoem.com/bmw/enUS/show...diagId=17_0023
        part# 17111712004
          I had never given it much thought but that's not the original clip I am familiar with. It must have been updated.
          You do realize you are looking at an early 325 coolant tank diagram right?
          61131369373 is the one on my early 5/87 produced 88.
            I do realize that. I have searched the clamps in the m3 diagram and I am given this part. I ordered 2 of them, but for the life of me I couldnt figure out how they are supposed to fix to the body.
            If you know how to get these clips to stick to the body, id love to know!
              Those clips above are for that hose but not those holes at front
              those clips are for holding it along the side of the car in engine bay
                Yes, but how do the clips attach to the engine bay?
                  Just slide to one side can stick on abit 😀
                    The clips at the front I want to say clip onto the plastic trim behind the headlights...
                    -chris
                    1988 M3
                    2007 Lotus Exige S
                      I think pictures might help here. If anyone is bored at some point this week and wouldnt mind snapping pictures of how their hose is fixed, it would help a lot! Its definitely not obvious where the intended clips go.
                        i can't get any pics till sat but your looking for two metal pins coming out of bodywork about 3mm they are hard to see if the clips where not already there
                          I can wait Ill take another look though when I get the chance
                            Above the headlight area there should be 2 small "T" beams for lack of a better term that stick out of the sheetmetal. The clips slide and clip over them sideways.
                            They may be an M3 only feature on the core support. If you have another style core, they may be absent.
                              ok found this in my pics will get better pics at weekend
