Cooling Fan help
    Glad it worked out to be a relay, you could have been going through a mess of wires. When you pulled it, you may have corrected it (assuming it was a pain to pull), the lever/arm probably burnt itself (you can visually inspect this by removing the cover of the relay if your interested). I think a relay from bmw is only 16$ or less, I would replace.
    Mario
