rare electrical issue 11/87 M3
  • rare electrical issue 11/87 M3
    hi good day
    car was siting for 10 years
    just finished rebuilding the engine and electrical
    now i got some strange problems
    when i turn on hazzard lights : hazzard lights + obc screen + license plate lights + parking lights , will blink together
    when i turn on lights switch without key , the radio will turn on
    main relay new
    fuel pump relay new
    evap relay old
    car is 11/87 ,
    i was checking C101 and reading about a pin 20
    where can i start looking ?
    thanks
    I would start by revisiting every wiring harness earth point then one buy one remove each indicator bulb to see if it is related to a individual indicator.
      thanks for advise , yes this sound like a ground problem
      its posible , a bad bulb cause shorts ?
      should check every single bulb in the car ?
        forgot to mention when car if off the green lights on cluster still iluminated even whithout key
          No just the indicator (turn light) bulbs which is what works when the Hazard lights are going, that is after you investigated each earth point.
            i just take out the rear turn bulbs and it fix the obc blinking , obc works good without the turn signal bulb
            so confirmed my short should be in the turn signal wiring
            besides this , when ign swith in pos 1 , the 2 pumps are working
              See if you can find where the rear turn bulbs earth point is, or for a quick trial add an extra earth wire to the tail lights to see what happens.
              Just incase it is earth problem not a short circuit in the rear lights.
                UPDATE
                hi just figure it out , my problem was a G300 ground point , i forgot to put it , rear seat
                just put them and now everything is working great
                thanks for help
                erne
