Part number help?
  • Part number help?
    Cant seem to find this vacuum hose on realoem or BMWfans
    vac hose that goes from the icv line and then down through the motor support arm and up to a check valve which leads to the charcoal canister.
    Its quite long, has a barb on the icv line side and chaffing protection tape on the check valve side.
    Any numbers? Not seeing it in the diagrams
    Side note: When looking at the diagram with icv, #17 only has 1 bung for barb fitting. mine has 2 and the second one is not shown.
    The only place i can see mention of the hose is on the charcoal canister/evap page. It shows the hose for reference but no pn.
    weird
      http://2009.bmwfans.info/parts/catal...urb_air_valve/
      M3 Sport Evolution 1990
      M3 Late Model 1990
        Forgot the protective hose number: 12141306988 as the #16 shows: http://2009.bmwfans.info/parts/catal...ection_system/
        M3 Late Model 1990
          Thank You! I have no clue why I didn't check that page. Those diagrams are always spotty considering the non ITB and not showing the path to the ICV first. Super confusing.
          Thanks for help friend.
