This is a wild one...for me anyway. Parked this car for 3 weeks. Was running perfect. Now, it won't start unless I pull the CTS connector and then it runs terrible. It appears the injectors are not firing properly per DME signal. I think pulling the CTS just richens up the injectors to the point where there is so much fuel in the cylinders they are firing out of order. Very high idle with the CTS pulled and hard to keep the car running. Fuel pump is fine, perfect pressure. 12v+ at injectors. Swapped DME, same issue. Spark is perfect. Timing on the money. Coil/plugs/wires are all ok. Tested both reference sensors, both ok. Swapped, same issue. Swapped out CT, ICV, Relays, O2 sensor, AFM, etc etc from my other 2 cars. I am now to the point of tracing wires from the DME since it HAS to be something on the negative side of the signal wires coming from the DME to the injectors. I mean I just can't see it being anything else? I know the injectors batch fire by the DME transistors grounding them. I'm just thinking something is interfering with that?
Is my thinking right or am I missing something obvious?
Don
Don
