Solved....Chris, can't thank you enough for forcing me to look at the fuel circuit. For a 3rd time!! The cause of all this was a simple split in the tubing between the fuel pump(in-tank)and the hanger. I'm going to assume it's been there since day 1 when I installed it 6 months ago. I'm also going to assume it began to tear larger at some point AFTER I tested fuel pressure which was perfect. It's a neat "knife slice" cut parallel to it's length. It was the correct tubing (submersible)and came supplied with the walbro pump so it wasn't from degradation. I'm going to assume again it simply ripped larger from the FP pressure until it had an effect on the cars fuel circuit.
I still don't understand the reason behind having some fuel when I pulled the CTS enough to drive the car between my garages. But when I put the gauge back on last night I had ZERO fuel pressure and that was NOT the case before.
So I'm going to finish this saga with new fuel tubing between the fuel lines and the fuel rail and of course replace the piece between the pump and hanger. I'll be doing that tonight and report back if that indeed was the issue.
Thanks again,
Don
Thanks again,
Don
