Shim under bucket valve lash caps
  • Shim under bucket valve lash caps
    Wondering for those who run shim under bucket if there is a maximum thickness for the valve lash cap. I am swapping cams with a smaller base circle while keeping the same valve length and need a thicker valve lash cap (range 4.4-4.65mm). Before they were 1mm shorter.
    Will going thicker increase the risk of the lash cap slipping out or rocking out?
    Joseph
    Joseph
    I am currently running the Supertech shim-unders....3.5mm is the thickest shim they offer. It is a bit of a different design...just uses a small metal disc that fits inside a recess in the bucket.
    My previous setup I was using Arrow buckets along with lash "caps" on the valve stem. I'm not sure how thick those were available.
      My supplier (here in Norway) delievers up to 5.0 mm
      so it should be possible to find
        Mine are in the 3.9-4.25 region.
        nilsp, care to share your suppliers details?
        Sport Evo No.47
        My Sport Evo Restoration
          Hi Steve,
          of course.. dont know personally or anything, and his webpage is in norwegian.
          But try shoot him an email;
          post@kmcams.com
          brgds,
          NilsP
