After searching on this site it seems that there is a lot old info on Recaro SRD seats. What is recommended for installing these. I want them to sit about the same height as the stock seats or SLIGHTLY lower. ( I am 6'1") I assume I use the OEM tracks ? Thanks in advance for the advice.
Recaro SRD
Someone else will probably chime in with solid info, mine is old, but when I bought the M3 that would become my race car it was a track car and had a pair of SRDs in it.
If I remember right, the mounting was a tiny bit of a kluge between the bottom of the SRD and a factory slider.
Im short (5'7") and if I remember they were just right for me and I think they were dropped on the lowest bolt holes that were possible.
They were installed by the previous owner, so the part that I dont know is,,, if there was a better way possible.
I liked the seats, they were super easy to sell when I sold them 20 years ago LOL.
Cheers
jimmy
I had SRDs in mine many years ago.
I used the Recaro sliders, but for the life of me I cannot remember where I got the mounting bases that the sliders attached to. But I do remember they were very low, and mounted the Recaro sliders almost right on the carpet. That worked for me (I'm 6-3).
Jimmy is right, when I put in racing shells the SRDs sold instantly, for very good money.
No experience with these yet, but it was what I am hoping to go with when do get some Recaro's or similar aftermarket more supportive seats.
Massive Brakes:
Please share what you do end up going with and how it works out!One letter. One number. One legend ///M3.
wedge engineering was the old go to for seat mounts. I probably still have them in my car, still running my recaro's in my street m3. Looks like now they call themselves Wedge Brackets:
Why Wedge? There is a reason why the top aftermarket seat companies in the world choose Wedge. For nearly 40 years we have built and designed brackets for virtually every seat manufacture in the world. We are universally known as the seat bracket experts. We have had almost every vehicle ever made in our physical possession in an effort to design a seat bracket that would allow you to install your aftermarket seat with little to no modifications. If you ever pay a dime more than what a Wedge bracket costs, you are wasting your money. Wedge brackets have a lifetime warranty and if for any reason your bracket does not work the way you expected, we will custom make one to your liking. We are the only company that truly understands what it takes to build a custom, direct bolt in bracket. Those words “custom” and “direct bolt in” will save you a lot of time and headaches, take our word for it! There are so many variables that go into making a custom bracket. If the height of the bracket is not just right, your head will be in the roof. If the seat belt tab is not in the right place or the bolt hole is not the correct threading, the stock belt will not work as intended. If the holes in the bracket are not in just the right place, you will not sit centered to the steering wheel. Those are just few of the several variables that go into making a custom aftermarket seat bracket. If you have any questions regarding seat brackets or aftermarket seats, please do not hesitate to give us a call at 801-555-5555 or email us at [email protected].
Cheers
Originally posted by Ironhead View PostAnother option....any fabricator could make a set of bases with about two hours or less of labor and some steel stock. They are very, very simple.
They also didnt go that low as you described yours did.jimmy p.
Originally posted by stark22 View PostLooks like Wedge Engineering is out of business. I looked into buying new E30 BMW rails ($2800) and garagetastic brackets ($140). Any other solutions to install Recaro SRDs?
Thanks!
Massive has brackets too.
Thanks!1989 E30 M3 Cabrio - Nogaro Sliver / Black - 1 of 786
