Fan switch cooper washer ??
  • Fan switch cooper washer ??
    HI good day , please if anyone can help me , realeom doesnt show any cooper washer for the fan switch , number 18 in diagram , does this switch should be mounted with teflon tape or cooper washer ?
    https://www.realoem.com/bmw/enUS/sho...diagId=11_0784
    thanks in advance
    BMW parts 3' E30 M3 COOLING SYSTEM-THERMOSTAT/WATER HOSES
    I would use a copper washer...
    It does not need to come from BMW....any decent auto parts store will have a variety of copper sealing washers. They are used for an endless array of things. Even hardware stores have them.
    Just measure the sensor so you know what size you need.
      Looks like part 20 in the ETK is the part, a 14x18 washer.
      Going from memory here, the thermostat has two identical holes, one for the switch, and one is for a blanking plug which uses a washer.
        Copper, aluminum or fiber (original on early models) is just fine.
        Don Fields
        MrMCar
        www.mrmcar.com
