Updated TPS for Maxx Alpha-N
  • Updated TPS for Maxx Alpha-N
    Has anyone updated their MAXX loom for the newer TPS with rectangular connector? My round connector TPS in intermittently failing and showing 55% throttle, even at 0 throttle. The round connector TPS is either NLA or very expensive, if it would even ship...
    When did the rectangular connector come out and is anything different?
      When I sent my Maxx unit in for closed loop upgrade last year I converted to the newer TPS at the same time. I believe the newer TPS is used on the S54 motor and it is far easier/cheaper to get. Martin made a small harness for me with rectangular plug end. From memory, this made it a plug and play setup in the engine compartment with no cutting/splicing. I still have the round style TPS that was working when removed if you are interested in it.
      Charley Terhune
      89 Zinno M3- stock 89k miles
      89 Zinno M3- 2.5 etc. etc.
      88 Alpine M3- 85k miles
        John, on their website, there is a link for installation instructions for old Bosch style TPS, and a different link for M50 TPS. On page 6 here you can see the new TPS setup with a spacer
        http://maxx-automotive.de/ftp/alpha-...4_140600en.pdf
        I'm curious if there is a performance benefit (i.e. response/accuracy) to the newer M50 TPS. If so, it might be worth upgrading. If not, I'll shell out the $400 for Bosch S38 TPS :( https://www.turnermotorsport.com/p-2...tch-e34-m5-36/
          PM sent!
