Does anybody have the temp sensor wiring order?
  • Does anybody have the temp sensor wiring order?
    This temp sensor has: ground, low temp, and high temp. What pins do each one go to?
    Thanks for the help,
    Todd
    1988 M3 zinnoberrot/schwarz
    Not sure what you mean but the pin numbers are on the female connector which only goes on one way, so it will tell you which one of the bottom two are low speed and high speed. The top pin #1 (GN/BK) is ground. Pin 3 (BK/BR) is high speed and pin 2 (BK) is low speed with the resistor pack in series.
    89 M3 - SEPANG BRONZE/SCHWARZ
    • Todd
      Todd commented
      Editing a comment
      Thanks, I appreciate it; that’s the info that I needed
