Front ABS rings
  • Front ABS rings
    just pulled my front bearings for replacement. Used the E28 bearing/hub. Planned to change out the ABS rings. Unfortunately it appears that my DAPO never changed out the rings (no wonder my ABS is not working properly). So now I need a set of 48 tooth ABS rings.
    anyone have any or know where to get them? Thanks
    Not available as an individual part. You're only hope is if someone has a pair hanging around. Otherwise, you'll have to buy a pair of new (or used if you can find them) front hubs.
    Ron ///Man
    • '89 M3 M3T / ITR Club Racer
    • '94 Spec E36 - Eh....
    • '09 M3 - Tarmac Terrorist
    • '07 530 Xi - Highway Star
      There was a thread running a while back that I think I asked the question is the ID of the rear E30 ABS rings the same ID as the front ones?
      If yes,,, that would mean that ABS rings off of any one of a million E30 rear axles could donate its ABS rings to someone who needed a set.
      I dont think we ever arrived at a conclusion of that question, but if someone has an E30 axle somewhere they can pop apart and pull the rings off.
        https://s14net.vbulletin.net/forum/s...ront-abs-rings
          Jimmy: My recollection is that the rear tone ring is an integral part of the outer CV joint, and not removable from it. I have an axle that I will check and let you know.
          Ron ///Man
            Anyone know if anything here works https://www.onlinecarparts.co.uk/mapco-2040326.html.
            Looks like the I D is right, the tooth count is right, the picture and OD are not right. But if the sensor just sees the right number of teeth......??
            sent them an email. At this price maybe worth the chance
              Thanks. Im on the road until Jan, so I cant check any of mine. Would be good to know if they were the same ring (and removable)
                The OD matters because it impacts on the clearance to the sensor,,, and,,, I am assuming even if the spacing worked for the sensor, a difference in OD could reflect a difference in speed relative to the others.
                  Many years ago this site used to sell their own E30 M3 ABS rings individually.
                  https://www.ultimategarage.com/
                  They also sold E28 hubs with their E30 M3 rings already pressed on for less money than what an OE hub would have cost. (I bought a set around 2008)
                  Maybe they'd be willing to do another run of the rings. I'd buy a set if they did.
                    ultimate garage closed down, Steve retired.
                    The best bet at this point would be to take a ring and have it scanned and make a bunch of them. Only other way to get it is to overpay for the e30 m3 hubs.
                      I bought the last rings from ultimate garage several years ago!
                      Got one last set myself, but has been looking to find something similar to use.. no perfectly similar yet, but I have found a company that can make!
                      Price estimate is around 50 usd if someone is interested at that price.
                      They want me to send one to copy..
                        Just saw your post re ABS ring. I would like to buy 2. How do I go about this. Thanks
                          As it turns out, I bought three rings and so will have a spare that could be sent out to use as a sample to take measurements from for making these. Let me know if interested.
                            Does anyone knows the OD of the E30M3 ABS ring, I have Timken 513094 bearings, it shows that it works on E28 M5 and E30M3, for what I have read above they are different, I compared to an old E30M3 ABS ring and it has the same number of teeth ID and OD are the same, what I do see is the ring are not pressed in to the same dept which might cause bad signal.
                              I am interested. we are talking about the ring with 48 teeth right? I see many new hubs ( after market ) have 96 teeth.
