Help , I can’t get my brake lite to go out on the overhead check panel , 88’ M3 . 21w bulbs (2) & 18w third lite What am I missing ? I have a 91’ IX so I know how the panel is so post to work . Thank
Overhead panel lite won’t go out ?
Usually this is caused by a faulty brake light relay in the trunk, or by lamps that are old and drawing too much power. Easiest would be to replace all of the lamps. If that does not fix it, replace the relay.Ron ///Man
- '91 Gr-A Former CiBiEmme / Ravaglia - Sold
- '90 M3 Faux EVOII Alpineweiss 36K Orig Owner - The Queen
- '91 M3 Faux EVO III Brilliantrot Euro Driveline - The Rocket
- '91 M3 Faux Gr-A Club Racer DM - The Alter EGO
- '89 M3 M3T / ITR Club Racer
- '94 Spec E36 - Eh....
- '09 M3 - Tarmac Terrorist
- '04 330Xi Sport 6 Speed - Snowmobile
- '07 530 Xi - Highway Star
- http://www.imwcarparts.com/e30-m3-parts.htm
I think I misunderstood... I think you are saying the warning light flashes even after you push the button to cancel it? If so, then disregard my previous post. What I described is when the brake light is flashing and everything seems to be working properly. If you cannot cancel the warning, then I'd say the unit itself has probably failed. Maybe swap the one from your IX to the M3 and see if the problem goes away.Ron ///Man
Thank you for responding on my control panel brake lite problem . Pushing the brake pedal cancels the flashing dash lite it should. But I can not get the control panel Brake lite to cancel out . I did swap out my control panel from my IX 91’ . It is an airbag car & has airbags warning on panel . It’s raing & cold today so I might not go out today . Isn’t there a long ish black brake relay somewhere in that car if I remember right ?? Thank you for you thoughts , Joe
Never heard of this sort of problem before, but hey, these cars are getting older. Yes, the brake light relay is in the trunk behind the left trim panel near the amplifier if I recall correctly.
Ron ///Man
Cool!! Post a link here so others can find it.
Ron ///Man
